TwEECer RT on Speed Density
    I just ordered one, should be here on Tuesday.
    Should be fun, can't wait to play with it!
    so tell me...this plugs into the ecm or something?
      It is a tuner (with datalogging) that plugs into the J3 service port, ya.
        J3 service port is where?
          Sounds like it will be fun!
            J3 service port is under the plate on the other end of the ECM. http://www.fordfuelinjection.com/?p=77
              ive been wanting to buy one for my truck project. they seem pretty nifty
                ahh, well this should indeed be fun to play with.
                  I hope you got a D9S mark 7 or Mustang DA1 ECM, other wise it no workie according to the Tweecer website.
                  I had one of these a while ago. used one I got off corral.net
                  Never could get it to work correctly, I suspect it had a fautly connection at the J3 port connector.
                    tweecer.com
                    I haven't had any issues with mine. Has worked well, even though I only got the base model (without datalogging)
                      I got a DA1 in the car now. Got a D9S just in case, too.
                        just out of curiousity whats the difference, other than the cruise control feature of the mark 7 computer
                          That's the difference between a mustang HO computer and a mark 7. The integrated cruise. Nothing else signifigant.
                            The DA1 is also a manual transmission ECM, so it has a little less initial timing. Theres also a possibility that the Mustang one doesn't have the speed limiter. Mark VII brains are limited to 110 mph, though in his particular case it won't matter. No VSS input on an 87 wiring harness, so no speed limiter. I'm not sure about the speed limiter, but any of the other parameters can be changed, so the initial program values probably aren't so important.
                              no Tweecer yet?
