How big are the speakers in the door? I have the chance to get a nice set of either pioneer or alpine from my friend for cheap but i dont know how big or small i need.
Door Speakers
Around 6 inches i think is the size. I just needed to do a little modification (cut some lines around the existing speaker hole and bend them to make the whole bigger).~David~
I was at walmart this morning at around 2 looking at the pioneer and sony speakers. Friend wants $40 for a set of alpine ones. I think he said like 10 inch speakers. I want to do the dash ones and door ones when i can. Dash must be dead because i got no sound from them.2018 F150 XLT 43k
1970 Buick GS 455 Stage 1 44k
1968 Buick Riviera
10inch is BIG...there may be enough room for them but again 10 inch round is BIG..
i think the dash is around 4.5 inch or something. i used 4 inch ones and they fit as well.~David~
I was looking at these at the store to use in the doors
http://www.walmart.com/catalog/produ...ct_id=10765456
http://www.walmart.com/catalog/produ...ct_id=105693202018 F150 XLT 43k
1968 Buick Riviera
yea they will fit with a little modification, no problemo.~David~
i have 6 1/2 inch round speakers in all the doors of the cars here. some of the cars didnt have the door speakers, so all i had to do was cut the carpet and cardboard backing. the hole in the door was fine. here is a picture of how i mounted mine and i didnt have to mod the door any besides cutting carpet...
Ah Jim...but you mounted yours right ABOVE the carpeted door panel. I kept mine behind the stock speaker grille. In that case you will not have to modify the door one bit.~David~
maybe this helps....???
Photo is from a 1979 two door drivers side shell door.
Looks like i slipped a bit while holding the measuring tape...but it looks to be 6.5"~David~
i have 6.5" behind the factory grilles in my towny......if you have a 90-91 vic speaker grille you should be able to use 6.5" speakers also
