is there a special tint paint out there or what?i wanna do the parking lights and the rear lights on my 91 GM
light tinting
Theres a prodoct out called Nite or Night Shades cant rember wich. Comes in a spray can like spray paint. Seen it used many times on newer 98+ Vics, and some guy tinted his parking lights on the front of his 88-91 Vic.
http://members.sounddomain.com/sambos86
My 1979 F-250 Ranger Hi Boy
33/12.50 BFG Mud Terrians
390ci with a little bigger cam
Holly 4 barrel with K&N
4 Speed with granny gear
awsome, got to find that stuff!
thnx
Called nightshades, look at the pics of my car either in my sig or in my cardomain page. I used it, and embassy also used it on his car, but not as much.
-Jeff-My CarDomain Page
2002 P74
Arizona Beige
20% Tints All Around
Tinted Tailights
Clear Corners
Sound System
Leather Interior
hmm
if you try to heat it in the over to cure it... don't melt your lenses... who was it that did that again?
SuperFord Profile
Support safe sigs
-sigs should not exceed 600 pixels wide
-sigs should not consist of more that 25 lines (including pics) when viewed at 800x600
-Multiple images exceeding 600 pixels wide should have a space between them to allow for wrapping
-Total sig size should not exceed 60k
Remember, only you can prevent sig abuse....
dont know... but a burgandy GM LSS is going to look bad ass with tinted lights!
Re: hmm
Originally posted by Grimorif you try to heat it in the over to cure it... don't melt your lenses... who was it that did that again?
Personally, I would not use an oven. There is the issue of the flammable fumes and the risk of melting the lense.
Night Shades dries to the touch in less than 15 minutes.
Be sure to apply several thin coats and not one heavy coat. One heavy coat will tend to run, then you are FUBARed.
Follow up with several coats of clear gloss for added protection and durability. Again, use several light coats and not one heavy coat.
Some pics I took while tinting my tail lamps and reverse lamps can be seen here.
