my TV grommet ripped..
    the little rubber nipple on the end of my tv cable that holds it to the throttle body shreaded on me today
    i knew because the gas peddle seemed really loose and entierly to easy to push down, not to mention it shifting really strange
    so i pulled off into the home depo and bought a $2 pack of zip ties and used one to wrap under the rubber block at the end of the tv cable and up into the hole in the TB linkage where it usually sits. basically keeping the cable mounted in exactly the same place where it should be and moving with the throttle correctly. i was just going to keep it like this untill i went into work (napa) and could order a new one but the more i think about it the zip tie lookes stronger then the tiny rubber nipple that popes into that small hole. and considering everything being made so cheap in china now a days im sure the new grommet is no where near as strong as the old
    while it was broke i feathered the throttle as little as possible to get to somewhere where i could fix it. 2 miles or so. hopefully i didnt cause any irreversable damage? it was imeadiatly back to running as usuall when i left the home depo parking lot so i guess im good
    1989 Grand Marquis GS
    I have 4 zip ties on mine
      Good deal that you were able to apply a Band-Aid within a short distance. Reminds me of when I test-drove an automatic Mustang and the idiots selling it apparently didn't even know the TV grommet was gone, so I bought one and installed it before taking the car back. I tried to explain it to them, but they either didn't comprehend, didn't care, or both.
      Do you have a dealer near you where you can get a proper grommet?
        repace the gromnet right away!
          They make a brass one, and someone here must know the PN.
            ford part number #F3SZ-7H303-B
            if you work at napa id just get one there, its only like 5 bucks id just replace it
              zip ties break too ya know....
                thats the brass one right?
                  napa will only have the hard aftermarket replacement junk. I hate those kind of bushings and grommets... never exactly the same and harder to install.
                    The grommet on my blue car broke years ago...
                    Drove it for quite some time, manually shifting it. Then one day I was under the hood, and noticed it was disconnected... truly a lightbulb moment. Hooked it back up, and kept driving. Twas a serious noob moment, but the transmission was ok after that until I thrashed it and tore it up.
                      i couldnt find the grommet listed in the computer at napa...
                        Have you tried a dealer?
                          got mine at a dealer. ~$8, I think for the brass one. Part #F3SZ-7H303-B.
                          Edit: Teamfordparts.com has it
                            i'll stop at a deal on the way home from work tomorrow, see what up. thanks guys
                              Get the brass one from the dealer man, even if tis $10 that's still a cheap insurance in the longevity of your trans.
