Runnin rich
    Runnin rich
    My 85 cfi merc has benn running super rich lately. I'm getting like 10mpg wich really sucks. So far I have changed the fuel filter, spark plugs, plugged smog ports on the back of the heads, disconected the air pump and cleaned the injectors. I have a o2 sensor that I need to put in, but it is stuck and i cannot change it. My pcv valve is broke and disconected. What else can be done?
    check for vacuum leaks... the vacuum reading is directly related to how much fuel goes in... also fix that PCV system. My hose, valve, and grommet are all new.
    Soak the O2 bung in penetrator, and keep trying to get it out. Gotta have a fresh o2!!!
    also have you tried seafoam??
      I just bought regular engine seafoam+deep creep. The vacuum leak sounds probable but I have to fix my fuel return line first(it sprung a leak the first time I started it with the new trans, Thats good sign eh?). I'm going to NAPA soon to get trans cooler lines and pcv stuff.
        I fixed the leak and tried the seafoam today! That stuff is great. My car doesnt stumble or miss anymore. I still need to get the pcv valve and filter but I am flat broke now. After I go for a road test with the new trans I'm changing radiators and pulling that o2 sensor, what ever it takes I'm gettin that sum bitch out. I still need to get my alternator tested cause I dont think its right and its a little to late to return it if its bad.
          Ok, today I took it out on the road today and it eats up gas like nothing.
          I want to narrow things down, so I heard when the o2 sensor goes bad the computor goes into a "safe" mode where it runs really rich, is this right? Also would the egr have any effect?
            As I understand it when the o2 sensor goes bad, it quits sending a signal to the computer, so it runs it extra rich to be one the safe side.
            You could also try replacing the Coolant Temp Sensor... if its bad it can causes the richness.
            Has the timing been changed or checked recently? Im not positve how the EGR effects mpg... but while I drove with it disconnected I didnt notice any change.
              oh, and if the PCV is disconnected, you put a cap on the nipple for it right? If not, thats your huge gas guzzling vacuum leak!
                I did not know if the pcv was disconnected it would do that, since older cars run with breathers. Right now it is all off and I just have the hole in the rear of the valve cover awaiting a new one. The coolant temp sensor is newer so it should be ok. Thanks alot man!
                  Im not talking about the one on the back of the passenger valve cover, that one IS just a breather!
                  The PCV valve is stuck in the middle of the oil cap, which is sucked on by a strong manifold vaccum. Check that out next time you're in there. what about your timing?
                    OH! Well then, I seafoamed the real pcv with that deep creep stuff. The cap doesn't really make a snug fit on the valve cover, it always feels sloppy. I have a timing light but I did not know you could adjust it(according to my shitty haynes manual).
                      Wait, then where is the filter for the pcv???
                        the filter is the little sponge thing in the air cleaner.
                        Its still part of the crankcase ventilation, it just doesnt have actual valve in that side of it. I put a big rubber O-ring on my oil cap, that seemed to hold it in the valve cover better.
                          I thought EEC IV cars had adjustable timing, but EEC III did not. 85 should be EEC IV.
                          If it adjusts the same way as mine, it goes likea thisa: Pull the SPOUT connector from the harness that plugs into the side of the distributor. It looks like a small black fuse. Start the engine and set the timing to 10 degrees BTDC. The marks are on the harmonic balancer and you'll probably have to get under the car and mark the correct spot with a paint marker. Make sure you get the BTDC side since the balancer has marks for both after and before top dead center. It should be marked either Before or BTDC. I don't remember which. Timing pointer is on the passenger side of the engine, kinda between the air pump and the block, mounted right to the side of the timing cover.
                            Got the new o2 in and now I get good mileage. But now the car stalls when I come to a stop. Also when I let off the gas and just let it coast it stumbles and misses. And when I go to accelerate it will miss and try to stall out on me. The car had done this before I got it from my grandpa. It only happens when the car is warm though. Any thoughts?
                              Oh stupid question. I know how to check timing but how do you adjust it. I dont understand EEC-IV and all that bullshit. Computor controlled cars make me sick.
