View Full Version : Sub boxes (need pics)
Southern_Pride
07-18-2005, 11:54 AM
Im about to build mine and would like to see how yall got yours in the trunk. Im definitely not putting 4 buckets seat in again with the subs as a console like i did in the 90. Also where the hell do yall mount your amps at? I had it tied in with a rope in the last car and it looked rigged as hell because it was.
85crownHPP
07-19-2005, 07:17 PM
i just finished installing my amps up on the package shelf, with brackets holding it to the rear fire wall and trunk lid support. I think some one took pics of it this weekend... Ill take some once I clean up the trunk.
Southern_Pride
07-19-2005, 09:53 PM
Me and my buddy built some boxes and they sound awesome. I found a way to mount the amp. Pics tommorrow. And i also have to buy a capacitor. Headlights dim A LOT.
85crownHPP
07-19-2005, 11:33 PM
howmuch power are you pushing?
Southern_Pride
07-20-2005, 08:25 AM
380 wattsx1 rms. Not a lot at all really. In my other car the lights wouldnt dim it would just run the battery dead. Im buying a 3 farad cap. And as hard as it hits im not going any bigger.
Paul_
07-20-2005, 11:06 AM
you might want to do the 3g conversion. heavy duty stereos put a big drain on the alt and a cap really isn't the solution. more of a bandaid. the stock alt is only rated at 65 amps. do the 3g conversion and a whole world of amp ratings opens up :D
plus with the 3g you don't have to worry about fords shitty alt plug catching on fire. fortunately i haven't experienced that yet
Southern_Pride
07-20-2005, 11:18 AM
Well i dont need a bigger amp and i am going to do the 3g conversion. And im going to buy a cap. Probably get a cap first. I dont know why ford put such a small alternator on these cars with 20 lights on the inside of them.
85crownHPP
07-20-2005, 05:50 PM
what size power wire do you have???
Once I put in the 4gauge, I was pushing 350 RMS watts with 2 of the amps and had no voltage drop at all (I have a cap too) but then once i hooked up the other amp, making it 500 watts I could notice a slight drop.
Evil is right though, a cap just softens the massive voltage drops. If you are using more jiuce than your alternator can produce, a cap is useless except for maybe a microsecond, and most bass note last longer than that, lol.
Southern_Pride
07-20-2005, 08:25 PM
I had a couple of problems i got fixed. First off it is supposed to be 4 ohms bridged and its 2 ohms. So i unbridged it and it sounds much cleaner and also isnt drawing so much power now. Before it would drop 1 volt everytime it hit. Now its maybe .2 volts. Now im pushing 125 watts x 2 at 4 ohms and everything works correctly. My power wire is 8 gauge. And the amp is a pioneer and wont hold anything bigger than that. I have slot port boxes and they are insane. Best ever.
http://img.photobucket.com/albums/v321/Southern_Pride/Cars/P7200003.jpg
subs
http://img.photobucket.com/albums/v321/Southern_Pride/Cars/P7200004.jpg
my amp mount. Its wedged under the spare and it wont move.
DuceAnAHalf
07-20-2005, 08:31 PM
you should really coat those boxes in some polyurethane paint, because if not the first time they get wet you can throw them away
Southern_Pride
07-20-2005, 08:56 PM
They wont get wet. I may coat them but that trunk doesnt leak a drop. I am going to carpet them one day too.
DuceAnAHalf
07-20-2005, 09:04 PM
but you might have to open the trunk one day when it is raining
85crownHPP
07-20-2005, 09:52 PM
Im going to have to throw away my box eventually :crazy:
Southern_Pride
07-20-2005, 09:57 PM
When you do go with slot ports. The sound these things make is amazing. My system is weak compared to most in this area. There is a suburban around here with 24 10's in it. I know hes pushing at least 6500 watts rms as well. Fucking nuts. Anyway if its raining ill put stuff in the back seat. Ill do something to cover them one day.
Paul_
07-20-2005, 10:03 PM
dumb question. i've heard that you should get a box thats suited to your kind of music. if i listen to metal what kind of box would my woofers sound better in, ported or bandpass?
85crownHPP
07-20-2005, 10:07 PM
sealed :D
sealed boxes make good punchy bass, like the kickdrum makes. Metal wont have much lower than that, unless its industrial maybe. A good sealed box will go lower just as well to, everyone at Scotfesst can witness to that, if they were there for the Crystal Method light show.
My experience with ported and bandpass boxes is that they are great for certain frequencies and lack on others. And if the box isnt tuned for the sub, forgetaboutit.
I hear the snail shell slot box design is supposed to be miraclulous though.
Paul_
07-20-2005, 10:08 PM
cool, thanks for clarifying that pete
Southern_Pride
07-20-2005, 11:06 PM
Mine are slotted and tuned to the sub and i will say they are the best ive ever heard. Takes a lot of math to get the box tuned right but it is well worth it. My sealed boxes never hit this hard. These are so much more efficient its not even funny. I guess mine would be the snailshell design. The insides are like this.
http://img.photobucket.com/albums/v321/Southern_Pride/untitled.jpg
Blaze86Vic
07-21-2005, 06:11 AM
Woops, some how I missed this thread.
I don't use subs, but I do have an amp. Here is a pics of where it is at.
http://memimage.cardomain.net/member_images/11/web/731000-731999/731378_9_full.jpg
Lincolnmania
07-21-2005, 10:41 PM
i run two 12" subs in a sealed box, bridged to a 2 channel amp, the bass is incredible
gadget73
07-23-2005, 08:55 PM
Pair of 12s in a bandpass, but I'm not super happy with it. Bass isn't as clean as I would like it to be. The amp is jammed between the trunk hinge and the spare. I think I'm gonna relocate the spare over towards the hinge on the other side, then mount the amp to a board or something along with the cap and wire it nicely. It looks like ass right now.
BTW, a 3 farad cap is overkill, way too f'n expensive, and not that useful for what you're doing. For your money, I'd go with a 3ag 130 amp alternator and maybe a 1/2 to 1 farad cap. I got my 1 farad for under $40 from an electronics supply place. Its nothing fancy, just a basic Mallory 20v 1 farad but it functions the same as a fancy brand that costs a hell of a lot more. Even with the cap, the voltage would dip enough for me to see the dash lights flicker at stop lights. With the new alternator it never drops under 14v, so all is well.
Southern_Pride
07-23-2005, 09:22 PM
Im definitely going to go 3 g alternator. But i can get a Power Acoustic 3 farad cap for like 70 bux brand new. I dont need it now that i undbridged the amp. But i will need more juice soon.
DuceAnAHalf
07-23-2005, 11:19 PM
3 words - Imperial Folded Horn - that design PWNS all other box designs. But unless you are listening to stuff that is heavy with a Roland 808 go with a sealed box. I have 2 sealed boxes with Rockford Fosgate Punch HX2 12's on synth bass heavy music such as DnB or Florida breaks it seems a little weak (nothing that the controls on the crossover in the console cant take care of), but on stuff like Mushroomhead it hits tight.
