Well, here's the plan for the Truckster....
96 Explorer complete NEW engine (Gt-40 heads, Explorer Intake)
Comp cams XE264HR Cam
Motorsport shortie headers
2.5" exhaust
Mark 7 ECU
Wide ratio AOD (eventually)
26-2800 stall
3.73 Trak-loc
110 lph fuel pump
19 lb injectors
Underdrive crank pulley
98+ brake conversion
Stiffer front springs
and whatever else it needs....
The engine *should* hopefully make 300 at the flywheel. I'll see what happens. Still debating on getting the heads cleaned up before the motor goes in. It's only another 500 bucks....
Update 6/21/06:
19's are ditched for 24's
80mm MAF from a Mark 8
A9P Mass Air computer from auto stang
2003 Marauder Air box
2004 Vic PI Intake tube
1990 towncar driver side fenderwell
1990 Towncar coolant tank, washer bottle, and fan shroud.
2.5" exhaust
Mark 7 ECU
26-2800 stall
3.73 Trak-loc
110 lph fuel pump
19 lb injectors
Update 6/21/06:
