im kind of curious what it would take to make a c6 trans fit in a panther. i know they are much bigger than the aod, but they can take a lot more power than an aod could ever dream of. (i mean stock aod compared to stock c6) is the c6 the same size as the e40d? since i have one of those in my truck i could measure. i know the e40d is fairly BIG, but i dont think it would be unrealistic to fit one in a panther. it would get rid of that pesky tv cable. feel free to elaborate guys.
would a c6 or e40d fit?
why?
AOD/4R70W transmissions are reguarly built handle high HP engines.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
I believe Cowtown Cowboy's (CVN) '84 CVPI had a C6 in it when he got it (not original). I thought I remember reading about the tunnel being a little butchered.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by 88grandmarq View Postwhy?
AOD/4R70W transmissions are reguarly built handle high HP engines.Last edited by 70torino429; 06-09-2009, 03:17 PM.
C6 is about the same size and weight as an AOD. I've got cores for both in the garage, so if you really want I can try to get some measurements.
What sort of stuff are you seeing small-block C6 trannies in? The one I have is for a small-block, but I had been under the impression that most went behind either big-blocks or the 351M/400 which shared the big-block bolt pattern.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostC6 is about the same size and weight as an AOD. I've got cores for both in the garage, so if you really want I can try to get some measurements.
most of the ones ive seen, as far as small block c6s i see are mostly in late 80s-early 90s broncos and ford pickups, and theres plenty of those in junkyards. im not sure what year exactly they did away with them, somewhere in the early 90s (somewhere around 91-93 i think) they all got replaced with the e40d. but the majority of the late 80s ones could still be had with a c6, ive only seen them on rigs with the 351, so i dont know if they came on 302 trucks, but i would assume its a possibility.Last edited by 70torino429; 06-09-2009, 03:39 PM.
i can get an aod for 900 bucks that will handle 400hp......tci is crap
That sounds like an excellent deal .... lots of guys charge a grand for a stock AOD that may or may not have been built that carefully.
I take it you've had issues with TCI products?2012 Mazda5 Touring | Finally working on the LTD again!
Good point, a pal of mine told me a stock C6 can handle like 500-600hp. Not that that's required behind most Windsor builds ....
If you pulled one from one of the trucks you're seeing, how cheap can you get it rebuilt?
Oh yeah, be prepared for some headaches in the shift-linkage area ... Scott can tell you about that since he's got a C4 linkage I need to pay for once he gets that alternator tested ....2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostGood point, a pal of mine told me a stock C6 can handle like 500-600hp. Not that that's required behind most Windsor builds ....
E4OD is not gonna fit without some major sheetmetal massaging. I put a c6 in place of an aod in a truck and had no issues with the linkage.1989 Grand Marquis LS
Oh, interesting. Did you just happen to get one that used the same style lever?
A floor shifter might kinda-sorta help ... in fact, most aftermarket shifters are intended primarily for C4/C6 applications and require a $40-$50 extra kit to bolt onto an AOD car conveniently. I like column shifters, though.
I think my two-door thread may have notes on the shift linkage stuff .... in a nutshell, the AOD linkage bellcrank didn't line up with the bracket on the transmission, the lever was pointing the wrong way, and that sort of thing.Last edited by 1987cp; 06-10-2009, 06:28 PM.2012 Mazda5 Touring | Finally working on the LTD again!
Trans came out of a van. I dont remember what lever it had.1989 Grand Marquis LS
