View Full Version : Different Types of Fuel Injectors.
Bowman85merc
06-21-2009, 11:09 PM
Dont know if this is already here or not. :crazy:
But i found this just looking up random stuff.
Hope it helps some people.
Bowman85merc
06-21-2009, 11:11 PM
Woops, forgot the picture, and it wont let me Edit it...
But here it is this time :D lol
Dang, i spelt fuel wrong too :arg: ... could an admin fix all these mistakes please :D
Lincolnmania
06-21-2009, 11:25 PM
cool.....the mk8 and continental 24's are not pictured tho
fixed
cld783
06-22-2009, 12:20 AM
they also have different injector designs.. 4 hole vs single
Pirate
06-22-2009, 02:17 AM
Hey, I have a set of those for sale!
1987cp
06-22-2009, 09:23 AM
Nifty reference! I'd whine about it not including the ubiqiotus grey 14 lb. injector, but I doubt anyone really wants to see one of those ever again. :D
Bowman85merc
06-25-2009, 10:28 PM
was that just the stock lopo injector ??? Because it sounds pretty weak lol.
mrltd
06-25-2009, 11:37 PM
used in lopo 5.0's and the venerable 2.3L EFI motor.
1987cp
06-26-2009, 08:55 AM
The 2.3 too? I didn't know that. Was that only the base injected 2.3, and the turbo cars got bigger injectors?
85MercPark
07-31-2009, 09:00 AM
What's a gray fuel injector from?
P72Ford
07-31-2009, 09:34 AM
That'd be a 14 lb, I believe. LO 5.0, and 2.3, as Mike stated above.
85MercPark
07-31-2009, 09:41 AM
Thanks,
So if someone says they have an HO for sale and it has gray injectors I would doubt it's an HO....
1987cp
07-31-2009, 10:53 AM
*cough*
85MercPark
07-31-2009, 11:13 AM
*cough*
Yea yea, I hear ya... :)
Was waiting for Mike to chime in too...
1987cp
07-31-2009, 11:23 AM
I'm still curious about the answer between the different 2.3 motors, since I've been too distracted to look it up on my own ...
gadget73
07-31-2009, 04:17 PM
What different 2.3 motors? The turbo and non-turbo version? Thats really about the only different 2.3 I'm aware of, other than that funky 8 spark plug version used in Rangers.
1980c10
07-31-2009, 11:14 PM
The turbo 2.3 uses 36 lb injectors stock they are brown tops I belive
1990LTD
08-01-2009, 12:25 PM
What kind of difference would I expect to see if I upgraded from the stock injectors? Is this something I could do myself?
1990LTD
08-01-2009, 12:28 PM
also, which are interchangeable? could i use all of the ones pictured except the funky green one?
1990LTD
08-01-2009, 01:18 PM
and LB-wise, what are the ones pictured?
gadget73
08-01-2009, 02:43 PM
You can't change injectors without changing the ECM tune to go with it. Putting a 19# where a 14# lived will give you approximately 35% too much fuel at any given injector pulsewidth. So basically what you'd see is a car that ran horrible and got crappy fuel mileage, and would eventually self destruct from washing the oil off the cylinder walls and contaminating the oil with excess fuel. If the ECM were re-tuned to deal with a 19#, it would work but the stock engine just doesn't need more fuel so there is no point to it. Its also possible that the stock ECM won't accept a tune anyway. I don't believe its listed in what the tweecer supports. Doubt anyone would even bother messing with a lopo ecm anyhow. The first step towards making any power is switching things to HO spec, and those computers are all tunable.
And yes, this is something you can do yourself. Pull the upper intake, disconnect the rail, unbolt the 4 bolts holding it in, unplug the injectors, and off it comes. The injectors just sit sandwiched between the rail and the manifold, and are sealed with O rings. No magic to replacing them, just pull the old out, lube the O rings, and push the new one in.
1990LTD
08-01-2009, 03:30 PM
So it would more or less be an exercise in futility unless I was going with the HO bits and the computer as well, then? Thanks for the great explanation.
Lincolnmania
08-03-2009, 03:10 AM
injectors cam and ecm need to come in one step......mixes have been tried, many have failed
