Rear diff maintenance
    I am getting mixed information on this from a Ford Dealer and from a Mercury dealer. I have a 97 Grand Marquis. I just bought it and I was thinking about doing a rear diff service (drain and refill). The owner's manual says, to do it at 105,000 miles. The Ford dealer says it does not have synthetic fluid and should be done every 30,000 miles. The mercury dealer says it does have synthetic fluid and therefore should be done at 100,000 miles. The car only has 77,000 miles and it is not making any noise. At another point in the owner's manual it says, the rear diff should not serviced AT ALL as in NEVER unless it has been in water.
    Any ideas?
    1997 Mercury Grand Marquis (just purchased July 09), 1993 Cadillac Sedan DeVille, and 2001 Ford Expedition (wife's car).
    My Dad always says that for an open diff, leave it alone, unless there is a percieved problem. If its a trac-lok, change the fluid periodically, using the proper friction modifier.
    If it has 77K on it, and its a trak lok, change the fluid. If its open, I'd just leave it alone.
    I did my open diff at 120K. There was no reason to do it.
      do you have an open diff or limited slip?
        I'd change it. You're not going to hurt anything by putting fresh gear oil in there. I would probably go to a synthetic fluid though, just so you know what its got.
          A 97 should have the standard gear oil in it. It will not hurt it to change, so do it if you want to. I would agree with gadget73, go with synthetic oil.
