i was curious as to what the benifit is of a wide ratio aod over a stock one? also what parts are recomened if i wanted to have a wide ratio aod put together, like if i should get a different servo and wider bads and stuff like that?
wide ratio vs stock
The A servo was really intended for the narrower band. You get more clamping force either by using a bigger servo, or just using a larger band. You can do both, but as mentioned its not entirely needed, and it does give a rather firm OD shift.
Mostly the benifit is in the gearing. First and second are lower, so you have better off the line performance without changing the rear or giving up much in the way of highway economy. OD is a bit lower, but its not a big amount. There is a sticky somewhere around here with a final drive ratio of both transmissions side by side using various rear axle gears.86 Lincoln Town Car (Galactica).
it's called pick up a used 4r70w trans for the stuff
so im really just using the 4r70w for the internals. i thought someone made parts you could by. i didnt htink it was parts from another tranny
alright so i found a list of gear ratios and it does look like it could be a big jump. now do you change all 4 gear sets or just 1st 2nd and 4th?
i saw another thing bout messing with the valvebody and different shift kits. i was thinking bout using a forward manual with htis tranny too.Last edited by import convert; 07-10-2009, 09:35 AM.
Yeah... wide ratio is the entire gear set.
basically you are putting the wide ratio guts in your AOD case, mainly for the gear set, but also because there are upgraded/improved parts... like the 2" OD band and related parts.
The stock/AOD valve body works, but with the wide ratio gear set it cause an early 2/3 shift, even with a shift kit.
LenTech offers a modification on his valve bodies to help this, but I am not clear on what is done exactly.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Originally posted by import convert View Postso i take it ill need the rebuild kit for a 4r70w then? if it causes early shifts then i guess itd be a good idea for the forward amnual valvebody then
you are using most of the hard parts from the 4R70W, however there are still seals and some small pieces that specific the AOD.
havent seen a forward manual valve body, but then whats the point?
its called an AUTOMATIC transmission for a reason.
If you want to shift gears, get a manual transmission.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
so youre saying any automatic transmission that you can manually shift is pointless? then all hte money that these topend car companies spend to make a tranny with a paddle shift shift in thousands of a second is dumb? or all the drag racers that use an auto with a manual valvebody should go manual?
i know its all personal opinion but still i dont want to hear what you think i should do cause its what youd do i just want to know what i need to do to make a wide ratio aod and one of hte htings was to change the valvebody and a forward manual isnt a bad idea. nothing here bout me putting a 5spd in the car.
figured id resurect this thread and get more specific with it cause i want to do this on my aod rebuild. i know i need a rebuild kit for a 4r70w and i know i need some aod stuff.
do i just need the seal kit, pump seals, valve body gasket and a tail shaft seal for the aod?
as for the tail shaft, i figure id use 4r70w shaft or am i wrong on that?
Originally posted by import convert View Postfigured id resurect this thread and get more specific with it cause i want to do this on my aod rebuild. i know i need a rebuild kit for a 4r70w and i know i need some aod stuff.
If you had a good-running 351....then I'd say go for it. The wide-ratio set would work with the bigger engine. As it is, I'd just stick with the regular gearset in the AOD, unless you plan on tossing in a 351, and put lower gears in the rear to help with the launch.
the 302 isnt stock and yea i was gonna run 3.73s or 4.10s. the tranny thats gonna get rebuilt has over 230k on it and the last year of its life it was low on fluid and the tranny itself never had a flush/filter change. it got the the point that 4th was gone and then 3rd would slip and then make a bad noise if you reved it to try and get it to shift.
so basically id want swap out the internals since i figured theyd be no good. i was gonna use a tci forward manual with it anyways
Wide ratio works great with all engines. You don't have to have a 351 to gain anything. In fact, a 302 is better for a wide ratio, as it revs faster. But either way it's all just drops in a bucket, as the different in what you gain with a 302 vs a 351 is negligible. What really matters is that you are gaining a ton of low speed acceleration.
As was stated earlier, 1st, 2nd and 4th gear are higher ratios (much more so 1st than 2nd or 4th) so it will feel like you have changed the rear end gears when you take off from a light, but it will still feel almost exactly the same at highway speeds. 3rd is the same ratio.
The percentages that the gears change are as follows:
1st: 18.4%
2nd: 5.3%
3rd: 0.0%
4th: 4.9%
So when you are cruising on the highway in OD, your engine will be spinning 4.9% faster. And when you take off from a light, your engine will rev 18.4% faster. In real world this means that your car will accelerate about 10% faster in 1st gear, and very slightly faster in 2nd and 4th.Last edited by Blaze86Vic; 04-14-2010, 01:26 PM.
