351 swap intake thoughts
    So I wondered if anyone has ever considered an intake setup like this to keep the 351 fuel injected and still fit under the hood without having to hunt down a lightning intake
    anyway here is the set up with the medium height elbow which is 5 inches tall
    and here is the ultra low elbow I was thinking of its only 2.25 or something
    and here is the ultra low on an ls1 intake but you get the idea on height
    also I think to run the ultra low sideway like we would need you would need a spacer to get over the fuel rails but you could still possible keep it lower than the 5'' medium one
    Then there is the fabricated version i've found made specifically to clear the fuel rails
    So what are your guys thoughts and opinions on this option
    '90 LX 5.0 mustang
    Big plans
    That's how im planning on doing mine..its a good way to go to save space imo, the edelbrock only comes in 90/95mm but i beleive you can have a custom one made for bigger or smaller inlets, although you could just put a smaller throttle body on the 90mm elbow if your motor does not require such a large tb. What your building will dictate what you need, but the elbow is a very good way to go regardless.
      you think the regular 5'' one would fit under the stock hood
      '90 LX 5.0 mustang
      Big plans
        keep it fuel injected? Panthers did not have injected 351s.
        Thats not a bad idea, but you really need some motor under it to make good use of it. Not particularly cheap either but you can build a hell of a badass engine and feed it with one of those.
          Well i've always planned going turbo on the marquis but I have not had the funds to do so yet. The 351 swap just got added to the plans recently since they hold about 700 or 800 horsepower before they split the block down the middle vs. a 302 which splits around 500 horsepower generally. With the new job i'm starting I should also have plenty of extra cash to put back for said project. I do plan on collecting parts over the next year or so to do an almost identical setup to the very top picture. Basically a 351 with nice crank rods and pistons, maybe even a stock crank as they will hold the power but i digress. An ok set of heads and the intake setup listed above, with a borg warner s400 turbo feeding the beast. A management system of some sort and a killer fuel system. With a nice 4r70w behind it and a baumann controller to go with that.
          It sounds like something I should list in the '' dream panther '' thread huh? haha
          P.S. - I got a 97 2.3 5 speed ranger that will be taking over the daily driver duties. So the grand marquis is getting put in the garage in ohio and it's time to start collecting parts.
          please don't laugh at a young boys dreams haha
          '90 LX 5.0 mustang
          Big plans
            but since your using a carb'd intake you can stay with something like a performer intake to keep drivability
              could ya use that steup on an injected 351 truck engine and put it in a panther, or is the intake like totally different?
              People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf. ~ George Orwell
              1990 Crown Vic, 2006 Ford Fusion, 2003 Ranger
                True, the Performer 2181 is a great street intake, good up to more power than most builders will get out of their street 351s..
                The thing about the elbows is just as Gadget said, it will take big heads and a big cam to really make use of it, especially as the intakes specifically intended for EFI conversions are usually big single-planes. The reason for the long tuned runners of the stock EFI intake and Lightning intakes is because it helps build power right where your car can actually use it.
                On the other hand, if you were to modify a Performer 2181 for EFI duty .... I wonder ......
                Need to find someone who's good at fabbing aluminum, though.
                  would just need the intake drilled and have injector bungs welded on.
                    I wonder if that goofy aluminum-brazing rod stuff would be adequate for adding injector bungs?
                      Truck intakes are like 2 feet tall. The idea is to have something that fits under the hood. And yes, they are completely different, with the exception of the GT40 on the 93-95 lightnings, but they still do not fit due to the extra deck height of the 351.
                        Could always just order anything from these search results and mock it up for a test fit:
                        http://www.summitracing.com/search/m.../?Ns=Price|Asc
                        ... depending on how much $$$$ you want to spend!
                          They are just as tall, or taller. The box uppers are probably the best bet, but are probably still dang tall.
                            Yeah most of the after market fuelie intakes like the trick flow ones in the link dont fit the stock hood on a stang and they have more room height wise than a panther
                            '90 LX 5.0 mustang
                            Big plans
                              also im pretty sure the place that makes the fabricated elbows also converts any carb intake to a fuel injected set up
                              '90 LX 5.0 mustang
                              Big plans
