Running crappier after plugs and wires?
    Ok, I just changed the plugs and wires in the GM. I noticed all 4 of the driver's side plugs where oily with one being REALLY oily. When I finished and started the car up it seemed to run sort of crappy and smoke came out of the exhaust for a few seconds after initial start up.
    Is this bad news?
    Ok, I think it must be a sensor or something. I just re-did the plugs and they where all gapped at like .40-.45. I used a different gap tool and gapped them. The first one I used must of been out of spec or something. The car runs better now but still hesitates when it's revved. I'm thinking TPS or something.
      Are the new plugs starting to foul again? What year is this car? What did you finally set the plug gap at?
        I don't think they are fouling yet. I don't have plates or anything for the car so it's not getting drove yet. I gapped them per oem specs. .052-.056.
        Sometime this week I'm going to get my buddies "In Transit" plate and take it to his shop. I want him to go over the entire car anyway before we start driving it. He mentioned he thought that there is a passage under the throttle body for the EGR that gets clogged with carbon and can cause excessive tail pipe smoke, hesitation and the oil on the plugs as the restriction also causes excessive crankcase pressure.
        So I'll keep everyone updated on this. I'm hoping to get it to the shop sometimes tomorrow but for sure this week.
          there is a passege to the EGR from the lower intake manifold. That could be the the problem.
          Then i have to ask the obvious question, are the wires in the correct order?
          good luck!
          08 Lincoln Navigator L - 233k
          03 Mercury Marauder- 63k
            yea i had a 93 towny come in to the shop i worked at years ago with a miss, piss poor fuel economy and no power.......i checked the firing order according to my book and it was right......still ran bad after the plugs and wires........something was wrong with the self test connector so i couldnt get codes out of it, so i went to the shop down the street and got them to print out some alldata stuff to help me.......whe i got back to the shop i noticed the firing order was different according to alldata so i changed it and it ran like new.
              good luck!
              That's what my buddy was saying when I dropped the car off at the shop today.
              Yeah, they are 100% correct. I did one at a time and double checked with the book.
                I know you checked over them, but it's REAL easy to mix up the #7 and #8 cylinder because of the wire lengths provided with most of the 'tailored' 4.6 ignition sets. If you have these cylinders mixed up, the car will run and will have the exact symptoms you posted.
                -My Homepage, Panther info & FAQs-
                My Mint 96' Mercury Grand Marquis LSE -
                Modifications
                Click My Merc for more Pics!
                  I believe they also changed the firing order in 95.
                    With the coil packs having the numbers printed on the top, This should be an easy fix.
                      He said he didn't think it was a bad ring. He thinks it's coming from above the plug, which srt of makes sense I guess sense when I changed them the threads and everything where soaked with oil and it doesn't really blow smoke, except on start up sometimes. He's putting dye in the oil and is going to try and find the leak. He's looking the entire car over and said he pulled codes saying the engine was running lean on both side of the engine. He checked for vacuum leaks and nothing and said he thinks it's the maf sensor. He's going to clean that and reset the computer and see if he still gets the codes.
                        Here's this... Just so you can keep it for yourself.
                        Originally posted by Bluemobile
                          I'd still sure like to know what year this car is. If it's an older 4.6, it could be that the valve seals are leaky, which would cause the problem you're experiencing.
                            1997 4.6 with 71,000 miles.
                              What plugs were used?
