PDA
View Full Version : Got my springs done
Central50
08-01-2005, 11:19 AM
After waiting for so long to do my springs (convert to 2004 springs) we did them yesterday and it makes a hell of a difference. We tried to do the seal on the tail of the tranny but we just cant get those bolts off where the driveshaft meets the rear end..
texasvic
08-01-2005, 11:23 AM
When I did my driveshaft I had the same problem. What I did was get the bottom two then put the trans in neutral and rolled the car back just a little. So the bolts that were on top are now on bottom.
Blaze86Vic
08-01-2005, 12:43 PM
It takes quite a bit or torque to get them off. A 250ft*lb impact wouldn't get mine off. I had to use the 3' breaker bar, and still had to give it my all.
texasvic
08-01-2005, 01:03 PM
lol I thought you meant you couldn't get to them.
Yes, they were a little tough, but nothing I couldn't handle.
rietan01
08-01-2005, 03:47 PM
Springs are a bitch to do... I am not one to know much... but I help Chris when he was doing his and fuck that shit man... that took forever and lots of things got thrown in walls and at me (no jk) but man there was lots of anger in that barn!
Grand Marquis GT
08-01-2005, 03:49 PM
Rear springs??
I did mine in my parking lot with jackstands and a POS jack...
Here's marcus teaching everyone the WRONG way to do it.. :crazy:
http://www.grandmarq.net/images/springs%20002.jpg
RustyShackelford
08-01-2005, 03:51 PM
are all models springs a real bitch, or just the Aero-boxes? I am going to have to get to mine soon............
texasvic
08-01-2005, 04:00 PM
The rear springs on my vic were easy to swap.
85crownHPP
08-02-2005, 08:15 PM
front springs are the hard ones... and the dangerous ones...
my rear springs came out after taking loose the bottom shocks and lowering the axle housing down.
mrltd
08-02-2005, 09:48 PM
Fronts are somewhat tricky. The rears are a half hour job. Jack the car up, put it on stands, jack up the axle, take off the lower shock mount, and lower the axle, pop the spring in...
p71towny
08-04-2005, 11:46 PM
It was the front springs when I put the polly bushings in, what a whore on my towny. Other cars went great but the towny was a whore. I got rear bags biatches :guns:
Johnnyiroc
09-01-2005, 08:13 PM
Yep you got it! Takes longer to get the tools out and put them away.
Johnnyiroc
09-01-2005, 08:18 PM
WTF did you do wrong, you jack up the frame, put a stand in there, move the jack to under the a-frame-lower cntl arm, remove the pinch bolt from the upper ball joint, if you have abs, I would disc the wire to the sensor, anyway, just slowly let the jack down all the way, take a walk away just incase you fubared something and the spring wants to go for a fly. When the jack is down all the way, you should be able to just lift them out. of course you have to remove the tire, and the shock first.
1BADMERC
09-05-2005, 06:29 PM
Jiroc-
The energy that is stored in an automobile coil spring, especially one in a full-sized car like ours can kill you.
I never understood how people removed springs without a spring compressor. I know it's possible, but I've seen too many horror shows over the years...
BTW, the rear springs are so easy it's a joke. The fronts are a PITA, but that's using a spring compressor. If that spring "wants to go for a fly", the potential danger is VERY great, the spring will go right into/through a thin wall, a person, any property around, etc.
Everybody has different ways to do things, but please, God, be careful, we'd hate to lose someone on account of something like that.
Good Day
Blaze86Vic
09-05-2005, 06:49 PM
:stupid:
Dont fuck with them. Horrer story follows...
Had a customer who need his controle arm bushing replaced, he refused to pay the labor to do it. So he tried to do it himself. A week later the car shows up on a truck, and need to be fixed. The engine bay got really screwed up, and the person... A broken collar bone, broken jaw, and a bruised rib.
DuceAnAHalf
09-05-2005, 07:07 PM
when i did the front springs on my 85 i just put the car on stands put the jack under the a-arm removed the upper shock bolt removed the upper ball joint, let the pressure out of the jack, and then removed the shocks lower bolts and had to pry the spring out, it was not in compression just kinda trapped in the arm because i did not have the car very high. reinstallation was pretty easy since the spring going in was much shorter (about 4-5")
