Clutch pulley on AC compressor doesn´t lock
    Hi All,
    The airco on my 1996 Merc. Grand Marquis doesn't work.
    The system passed the gaspressure test.
    After testing the electronics proofed to be good too.
    The mechanic told me that the clutch pulley on the compressor doesn't lock .
    Are there things I can do, before thinking about replacement of this compressor?
    Thanks in advance,
    Arie
    BDRUP BDRUP BDRUP
    Well, you don't have to replace the compresor to replace the clutch.
    I replaced my AC pully and clutch (you usually have to do both at the same time) about a year ago.
      thanks for your answer,
      Do I understand correctly:
      It is possible to replace the pully and clutch while leaving the rest of the compressor in its place?
      Tia,
      Arie
      BDRUP BDRUP BDRUP
        I think so...
        Im not too up to speed on A/C stuff... I do know, replacing the clutch is almost as expensive as replacing the compressor...
          Originally posted by grand_marquis_gt
          I think so...
          Do you mean parts or labor?
          BDRUP BDRUP BDRUP
            Parts...
            Labor, im not sure of...
              -Michael
                Oh glory glory, what a happy day. :party:
                I used a little hammer, and tapt the central bolt a few times lightly.
                Engine not running!
                Then I started the engine and wow, GOOSE-SKIN! and not because of emotion!
                I hope it keeps working, but anyway if it fails again, I now know for certain it must be the pulley (and clutch).
                Thanks all,
                for the help, :thumbsup:
                Greetings,
                Arie
                BDRUP BDRUP BDRUP
                  Good to hear.
                  -Michael
                    Good to hear man!
                    When I did mine it wasn't that much for a new pully and clutch. I think it was less that $70 for it all. Though it will be more for you being over there.
                      Good to hear man!
                      Yes, a few hundred.
                      I hope to prevent that.
                      BDRUP BDRUP BDRUP
                        I don't know if it helps or not but I blow my clutch out with the air compressor every once and a while. You wouldnt believe all the rust, dust and clutch material that comes out.
                          I dont have an air compressor, can I use WD40 instead?
                          Or will that do harm?
                          BDRUP BDRUP BDRUP
                            That would do harm, It would be like greasing your brakes.
                              I have a highpressure cleaner.
                              How about cleaning with high pressure (clear)water?
                              BDRUP BDRUP BDRUP
