Breaking Loose a Rusted Rotor
    I'm trying to replace the rear rotors on my '01, but the passenger side is rusted in place on the axle badly enough that I've been unable to move it. There's very little room in there to swing a hammer due to the rear suspension being in the way, and I've tried to hold the rotor in place with the brakes and then put it in Drive and Reverse to try to use the drivetrain's torque to make the rotor turn on the hub ever so slightly (that's usually how I break loose rusted drums), but to no avail.
    I've thought about yanking the axle shaft out of there, but that's more work than I really wanted to do, plus I'm not sure if I can push the axle in far enough to get the C-clip off. I know you can't with drums, but I've never tried it with discs.
    So, anybody got any ideas?
    Thanks in advance,
    Nathan
    Can you post a few pics from various angles? My imagination is failing me right now.
      if the rotors are junk, maybe a torch?
        I would try putting the lug nuts back on (to protect the threads) and take a BFH to the hub area of the rotor (esp. between the lugs). I tried this on a (ford ranger) brake drum a few years back....after several hits and wondering if it was going to shatter......there was (finally) a metallic riiiiiiiinnnggg!!!!!.....and it came loose (it was rusted solidly to the axle hub).
        I used to have an 05' dodge ram.....and the guys over on dodgetalk.com were often talking about how they took thier old rotors off.......in pieces......but the method described above was how most people got thier old rotors off (in one piece that is).
        Hope this helps you.
        Former panther owner
        1981 CV 351 4bbl
        1991 CV 302 EFI
          smack the crap out of the face (outside) of the rotor with a big hammer......soak the flange surface with pb blaster first......it will come free
            yes, get a bigger hammer and more muscles
              Are you commenting about my muscles, or lack thereof, Pete? :p
              Thanks for the tips, guys. I'll keep whacking on it.
                Natertater is strong for his width.
                    I've found that soaking with something like Liquid Wrench or WD-40, but then smacking the crap out of it with a big rubber mallet, will usually work.
                    No chance of damaging it as would be with a metal hammer, but the rubber mallet allows you to be a bit more wild with the swinging, and the vibrations will usually shake it loose.
                    1987 Ford LTD Crown Victoria 2-door Coupe - perpetually "sort of" for sale...
                    Black with Red cloth (velour?) interior.
                    Purchased on 10/10/2008, with only 70,386 original miles, and only ONE previous owner.
                    Reader's Ride post, First pic with "new" rims, Other pics with "new" rims
                      I used a 3 arm wheel or gear puller. Use PB Blaster with the puller. Get big one and turn the bolt until the arms are tight, hit it with a hammer, do it again. It will come off.
                        Aha, a good idea, and I actually have access to some pullers that I think would be big enough. I'll give that a try!
                          PB and a BFH. i use a 3 pound sledge. usually works pretty good.
                            The last time I tried a puller I actually ended up snapping the rotor in half. One half came off... the other stayed seized onto the hub.
                              Any progress with this so far?
