I have an issue with the check engine light coming on after hard acceration on the highway..... I just recently went from standard oil to Mobil 1 clean 5000 synthetic 2 changes ago... could that be the problem???
Check Engine Light
Re: Check Engine Light
Originally posted by importssuckI have an issue with the check engine light coming on after hard acceration on the highway..... I just recently went from standard oil to Mobil 1 clean 5000 synthetic 2 changes ago... could that be the problem???
Also there is a way to check your codes yourself. In the Haynes manual, it shows you how to do it. Basically all you have to do is jump a wire, then the "Check Engine" light flashes, and you have to count the flashes. Then the book has the codes, with the corresponding problem listed.
Hope this helps
Good Day1993 GM LS 244K
29.5mm PI front bar, ENS greaseable bushings, 21mm rear bar, ENS bushings, endlinks. Black steelies, center caps. Stewart-Warner mechanical oil pressure guage. K&N filter
1994 Lincoln Mark VIII 144K
All airbags are now coils/struts. Junk tranny, motor donor car
Mercury Owners Group
If you don\'t like what I have to type, don\'t read it. It is only my opinion, nothing more.
