the 1992 gmq i just bought had an after market head unit installed incorrectly, and the chopped up the stock connector instead of using an adapter, can any one help me with the wire colors and what they do?
need help with radio connector pinout....
Originally posted by aramilx View Postthe 1992 gmq i just bought had an after market head unit installed incorrectly, and the chopped up the stock connector instead of using an adapter, can any one help me with the wire colors and what they do?
allthough i have found with and older panther your better off just running your own wires but yours is a 92 so you should be ok.89 townie, mild exhuast up grades, soon to have loud ass stereo....
Oooh! Thanks for mentioning that site Zoomie.
Looks to be useful.
GSOwner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Originally posted by aramilx View Postthanks zoomie i looked and it had most of it but what about the thick solid red wire? it didnt have anything listed for that, also what is the ground, another thang that wasnt listed.89 townie, mild exhuast up grades, soon to have loud ass stereo....
Here is what i do when i hardwire a stereo. first thing first i find my power wires. only two you need to be concerned about are constant form battery and hot from switched( i usually use a testlight to determine this.) then i figure out where i want to put my ground, after that i hook up speakers wires (note check all wires to make sure you dont accidently put a power wire to a speaker) last time i did one of those there where two seperate plugs one for speakers and one for power wires. as i said before see about taking a picture for me and i can see if i can figure out your wiring. anywho once you do it a couple of time its pretty much standard constant,switched and ground most speaker wiring is fairly simple from there.
ah ha found something for ya
http://www.p71interceptor.com/radio/89 townie, mild exhuast up grades, soon to have loud ass stereo....
thanks zoomie, i will take a picture as soon as i can get my hands on a camera. i stuck the radio back in for now so i have tunes while i drive and just reset the settings every time i get in it for now, its not blowing fuses but it sucks not being able to use the memory features on my head unit.
in the diagram you posted i dont think i have that thick black one, the only thick wire is the red one.... i dont rember for sure though, i have C.R.S lolLast edited by aramilx; 12-05-2009, 01:45 PM.
Originally posted by aramilx View Postthanks zoomie, i will take a picture as soon as i can get my hands on a camera. i stuck the radio back in for now so i have tunes while i drive and just reset the settings every time i get in it for now, its not blowing fuses but it sucks not being able to use the memory features on my head unit.
in the diagram you posted i dont think i have that thick black one, the only thick wire is the red one.... i dont rember for sure though, i have C.R.S lol89 townie, mild exhuast up grades, soon to have loud ass stereo....
