Order my B&M Shift improver kit (AOD) from the local O'reilly, and will be in on wednesday. Has anyone used this kit, and what kind of improvements will I see? I am going to have it set up for stage 2. I am also going to outsource the job to a connection I have at the local ford dealer ( Sorry I dont have faith in my trans abilites aside from fluid and filter changes.)
B&M Shift Improver Kit
NA-15.78@91.21, 80hp shot-14.48@96.21Tags: None
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
I used a B&M on my '89 Crown Vic, and it definitely made an improvement, but I was disappointed that it didn't firm up the 1-2 shift more than it did. It was still pretty soft, but faster than it had been before. 2-3 and 3-4 felt very nice.
Thanks Nathan, A real issue i noticed at the track was the slow shifting and it would hold the gears too long before up shifting. My trans is in good shape with 85800 miles on it.
I saw almost no improvement after installing a B&M kit on my white '87. Of course, that was a comparatively weak-shifting transmission to begin with.
What do you mean by "hold the gears too long"? The usual problem with a Vic AOD is shifting way earlier than convenient.2012 Mazda5 Touring | Finally working on the LTD again!
I installed it on my car. It was a waste of money. It had snappier shifts but really didnt change anything.~David~
Originally posted by 1987cp View PostI saw almost no improvement after installing a B&M kit on my white '87. Of course, that was a comparatively weak-shifting transmission to begin with.
I thought AODs were just naturally extra-slushy.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
i had a b&m shift improver kit installed by my friend brian in 2004 shortly after my ho conversion.....it was slipping pretty bad at wot in the 1-2 shift.......shift kit new fluid and maxed out tv pressure
i like the shifts......my light throttle shifts are fairly harsh.......wot is not but that is just the nature of the aod
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Yeah, I've never seen an AOD that had a really firm 1-2 shift at WOT, at least not one that was anywhere near stock. The AOD in my '89 had a nice firm 1-2 shift at light throttle, but was a lot slower at WOT. The 4R70W in my '01 is the same way since I did the J-mod. 2-3 shifts are nice and firm at WOT in both cars. I guess it's just the way they're designed. I remember Larry making a comment before about the direct clutch pack being the culprit in that, but that's deeper into the tranny than most people want to go, methinks.
Okay, I'll quit rambling now.
stock AOD shift calibration is horribly mushy. Shift kits help, but I've never been in an AOD car that had a WOT 1-2 shift I liked. Even my car with its relatively fresh and otherwise very healthy transmission has a pretty mushy 1-2 shift. The Mark VII with its stock transmission has an outright horrible 1-2 though, so comparatively speaking, the Towncar isn't so bad.86 Lincoln Town Car (Galactica).
I like the way your car shifts, Thain. The first time I rode in it, I remember thinking... "oh, these shifts are crisp".. not something I usually associate with the AOD.
I have no thoughts on shift kits as they pertain to the AOD. One of these days I will fix the set-up in the red box. I have debated buying a complete vb, I have even thought of changing the entire transmission. I'll probably do nothing.
I did put a B&M kit (not the improver, the more complex one) in a GM TH400, and the results were *very nice*. Fast, crisp shifts; the transmission was otherwise stock, with the exception of a 3800 stall converter.
I have to admit that I am a fan of hard shifting automatics, however nonsensical they may be. The best shifts I have ever felt are in my Dad's '05 F350 6.0 diesel. When the transmission is not yet at operating temp, and you put the transmission in tow-haul mode, and do a slightly boosted launch, and go to WOT... Mmmm... mmmm..mmm. Just about hit your head on the rear window.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Nate I am drooling over your signature even though that is a fairly old picture that I have seen before.~David~
Originally posted by Nathan in MI View PostYeah, I've never seen an AOD that had a really firm 1-2 shift at WOT, at least not one that was anywhere near stock. The AOD in my '89 had a nice firm 1-2 shift at light throttle, but was a lot slower at WOT. The 4R70W in my '01 is the same way since I did the J-mod. 2-3 shifts are nice and firm at WOT in both cars. I guess it's just the way they're designed. I remember Larry making a comment before about the direct clutch pack being the culprit in that, but that's deeper into the tranny than most people want to go, methinks.
