This is my first post! So i've got an '89 marquis with some nice body rot, a cracked vinyl top, in need of fuel injector cleaning and plenty of other things, so of course the first thing i want to do is put in a 2 x 12 subwoofer. Duhh.
Problem: I have the stock head unit in there (E8DF-19B132-AA) which has the two stock connectors with all the colored wires and then i guess the power cable on the other side, but I need to run RCA cables to my amplifier. It doesn't have RCA outputs and I'm wondering if anyone has done any sort of soldering or used any sort of convertors to do this. What I did see is this extra yellow wire with three inputs slightly larger than RCA and I'm wondering if I can somehow use that. It's connected to the plastic wire arranger thingy....specifically its the 4th wire down, so it goes directly into the head unit.
I'd really like to avoid buying a new head unit, but if that's my only option, make a suggestion for me.
Thanks!
Thanks!
