installing trans-go NOYOYO shift kit...
    I'm going to be tackling the shift kit in a few days and i had watched the AOD HP vid and read over the NOYOYO instructions. Looks like it wouldn't take to much to make stuff go wrong lol, and I have read allot of other posts and i'm just looking for some tips and stuff to look out for when doing the kit in my 1991 marquis since lots of you guys have loads more experience than myself.
    thanks guys, andy
    I haven't done it, but the biggest thing I hear from guys who have is torque pattern specs are REALLY important.
      Working in a clean environment is the MOST important part of the job. It only takes a speck of dirt or a metal shaving to jam a valve in there. If that happens, then everything else means nothing.
