PDA
View Full Version : Tech Articles-Check Here First! NOW WITH J-MOD
texasvic
08-08-2005, 07:57 PM
In an effort to reduce the number of stickies I am creating this thread.
This thread will contain links to various technical articles and other random important information.
Ford OBD-II DTC (http://www.grandmarq.net/vb/showthread.php?t=2961)
More Ford Codes (http://www.grandmarq.net/vb/showthread.php?t=6160)
Upper Ball Joint (http://www.grandmarq.net/vb/showthread.php?t=1227)
Oil Filter Adapter (http://www.grandmarq.net/vb/showthread.php?t=1217)
Rear Axle Oil Change (http://www.grandmarq.net/vb/showthread.php?t=3432)
How to clean the MAF (http://www.grandmarq.net/vb/showthread.php?t=3303)
Some Suspension Stuff (http://www.grandmarq.net/vb/showthread.php?t=2742)
Ford Rear Axle Lube Info (http://www.grandmarq.net/vb/showthread.php?t=3735)
Ford RWD Transmission Ratios (http://www.grandmarq.net/vb/showthread.php?t=3738)
Air Filter Study (http://www.grandmarq.net/vb/showthread.php?t=3747)
Headlamp Adjustment (http://www.grandmarq.net/vb/showthread.php?t=5287)
Engine Miss (http://www.grandmarq.net/vb/showthread.php?t=5903)
Idle Problems (http://www.grandmarq.net/vb/showthread.php?t=5906)
Heater-AC Blower Speed Problems
(http://www.grandmarq.net/vb/showthread.php?t=5911)
Engine Schematic Diagrams (http://www.grandmarq.net/vb/showthread.php?t=7200)
EGR Tech Article (http://www.grandmarq.net/vb/showthread.php?t=24114)
Intake Swap (http://www.grandmarq.net/vb/showthread.php?t=9128)
PI Intake Swap (http://www.redpulsar.us/%7Ecoldfusion/intakeswap.html)
"J-Mod" Valvebody Mod (http://www.crownvic.net/tech/4R70Wnotes.pdf)
This video may be helpful for those who want a first hand look at most of the procedure. The use of the lower 2-3 spring in the lower 1-2 spot is AT YOUR OWN RISK. The use of an Impact Wrench to remove the VB bolts seems bullish to me.
http://www.youtube.com/watch?v=Yl1lGdQ9jwk
If you are still have not found the answer to you question...
Post it (http://www.grandmarq.net/vb/newthread.php?do=newthread&f=11) or PM seneeb (http://www.grandmarq.net/vb/member.php?u=272)
I have also started to upload exploded views of certain key things and other random tech stuff from a Ford service CD. They can be seen here.
Linky... (http://www.supermotors.org/vehicles/registry/detail.php?id=5428&s=27582#content)
Where to get performance parts:
ADTR (http://www.adtr.net/) Your Panther Performance Specialists.
Innovative Interceptors (http://www.innovativeinterceptors.com/) Tell Wes I sent ya. :D
Team Ford Parts (http://www.teamfordparts.com) Most discounts are 25% off Ford MSRP
I hope this helps.
Grand Marquis GT
08-08-2005, 10:06 PM
Great Stuff! :clap:
