fuel pump?
    fuel pump?
    OK the prob with my 95 town car the acceleration drags a bit the car doesnt always take off the spot when the gas is hit. It takes like 2 sec. after i hit the gas.
    I was told that it can be the fuel pump is going bad which i hope rather than the transmission going bad.
    What can it be?
    check the throttle position sensor
      If it was the transmission the engine would rev a bit before taking off.
      I'm with Scott, it's probably the throttle position sensor. You could take it off and have a local auto parts store check it for free.
      Axle codes
      Open/Lock/Ratio #
      G / H / 2.26
      B / C / 2.47
      8 / M / 2.73
      7 / - / 3.07
      Y / Z / 3.08
      4 / D / 3.42
      F / R / 3.45
      5 / E / 3.27
      6 / W / 3.73
      2 / K / 3.55
      A / - / 3.63
      J / - / 3.85
        It does kind of sound like the engine revs up a bit like it moving but it really isn't
          I would also replace the fuel filter. Check your trans fluid too.
            The trans fluid is fine but I'm not sure how old the fuel filter is I barely got the car
              if you dont know how old it is, replace it. they're like 10 bucks.
