How do I know if my 99 Grand Marquis has a limited slip differential? I was going to change my dif oil, and the guy at the parts store said there is an extra additive if there is a limited slip.
How do you know if your car has limited slip dif??
- Oct 2009
- 2878
- Keene NH
- Send PM
Do a burn out, if its one lone smoking tire mark its open rear dif, or you could do it the lame way above."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
You can tell by the axle code on the driver's door.
Jack up one back tire off the ground. Put car in gear. If it jumps off the jack it is limited slip.1989 Grand Marquis LS
- Oct 2009
- 2878
- Keene NH
- Send PM
Originally posted by torquelover View PostPlenty of LSD cars will only burn one tire. Limited, not unlimited slip."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
If you're changing the fluid, you'll see it when you get the cover off. If theres a funky S shaped spring in the middle, its a traction lock. No spring, no traction lock.
Or just read the axle code off the door sticker.86 Lincoln Town Car (Galactica).
yup rip a burnout, then if one tire spins you can check further and jack up the diff and if its an open rear when you turn a tire the opposite side will turn in the opposite direction quite easily, if you can't turn it she's Limited slip. at least all said and done you have ripped a burnout anywaysFinally have an on the books porting/custom fab business!
- Oct 2009
- 2878
- Keene NH
- Send PM
Ahah yeah ripping burnouts is always good. Especially in "Granny cars"."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Look at the sticker on the edge of the drivers door, and make a note of your "AXE" code.
Then look at my sig and see what you've got,Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
When the traction lock is really tired, you're not going to spin both tires. My car's was totally fried when I got it.86 Lincoln Town Car (Galactica).
Originally posted by 91grandmarquis View PostYeah sorry I was thinking posi. My bad but I never discourage doing burnouts.
Other types of differential that come readily to mind include:
Spool or mini spool (no differential action at all)
Torsen (gear-type torque biasing)
Locker (said to make a ratcheting noise while turning and be far from smooth in transition)
Air locker (pump it down it's an open, pump it up and it drives like a spool)Last edited by 1987cp; 01-31-2010, 09:54 PM.2012 Mazda5 Touring | Finally working on the LTD again!
- Oct 2009
- 2878
- Keene NH
- Send PM
Yeah my knowledge is kind of limited, I basically know the terms as open - Nothing locks, LSD - Some type of clutch to control locking, and posi - Power to both wheels at all times.
Ill check that sticky."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
