PDA
View Full Version : Water in my Muffler??
GrandMerc97
03-12-2010, 09:26 PM
Hey whats up, I have a question and i am not sure where it need to go but here it goes. I have a 97 mgm 4.6 V8 and it has 225,000 miles and still going strong. but lately when the can is in park i noticed that the engine itself shake every now and then, also when i rev it up i have been told that the muffler spits out a little bit of water. is that normal? And when i am at a stop light and then press the gas my merc will shake a little as it picks up speed and the check light will then start to flash for a while and stay on. does anyone know what might be the problem i love my car me and her have been go hell and back. help me please!!!!!
gadget73
03-12-2010, 10:58 PM
probably needs a tune up. How old are the plugs, wires, and fuel filter?
the moisture in the exhaust is normal with a cold engine.
jayh
03-13-2010, 11:31 AM
the flashing CEL is a misfire, probably time for a tuneup, most likely wires are the cause, dirty injectors are also suspect
GrandMerc97
03-13-2010, 07:02 PM
Okay thanks on the exhaust part. i think its time for a tune up too. what does a good super tune up consist of. also how can i tell if my injectors are bad or dirty.
jayh
03-17-2010, 09:08 AM
plugs, wires, fuel filter, pcv valve, air filter
get some injector cleaner you pour in the tank, spend money on the good stuff
sea foam is good stuff also
GrandMerc97
03-17-2010, 10:45 PM
does anybody know how much does the Ford house charge to put your car on their scan machine? Oh thanks for the input will be part and see what happens.
86VickyLX
03-18-2010, 09:49 AM
Catalytic Converter damaging if it flashes on and off.
jayh
03-18-2010, 10:02 AM
a flashing CEL is a current misfire, yes this can damage the cat, but thats not what is causing it to flash
GrandMerc97 if I was a betting man, I would say your plug wires are the root cause; dirty injectors are also a possibilty, but the wires being old is alot more probable
87DeuceVic
03-18-2010, 02:08 PM
I took my 94 Vic to the Ford dealer for a CEL and it was around $50 for the diagnoses.
GrandMerc97
03-18-2010, 05:47 PM
okay here is an update so far I call the ford Dealership in my area and they said it would be $90 to check to car. WOW thats alot but i will replace the wires and reset the computer and post an update but will just get autozone to check the CEL and post their results Thanks
