4.6 carb conversion kits?
    I recently ran across edelbdock's 4.6 carb conversion kit. (part# 2839)
    I also know a local guy who sometimes frequents this site, who was toying with one, but never finished it.
    While I don't see the point in doing this to a good running panther, it would be a very cool engine to run in an older project car, or rat rod. Especially due to the passing resemblance to the old ford y block.
    Aside from the high price of the edelbrock kit, 4.6's are cheap around here. I can pick up good ones, along with the transmission for $400-$600 all the time. (yes, I know the transmission is computer controlled, but I'm looking into that)
    It would make for a simple, reliable and super smooth project car, with as much power as a 5.0 HO engine.
    So now for the question...
    Has anyone seen any kit's other than the one edelbrock sells? Preferable one that doesn't have a proprietary ignition system.
    Thoughts?
    Axle codes
    Open/Lock/Ratio #
    G / H / 2.26
    B / C / 2.47
    8 / M / 2.73
    7 / - / 3.07
    Y / Z / 3.08
    4 / D / 3.42
    F / R / 3.45
    5 / E / 3.27
    6 / W / 3.73
    2 / K / 3.55
    A / - / 3.63
    J / - / 3.85
    sullivan makes an intake
    there was a company making adaptors to put a carbed 302 intake on a 4.6 4v, but I cant remember the name of the company
    the pi 2v 4.6's make quite a bit more power than 5.0ho
      KarKraft made a bunch. They went out of business but still sell their products through eBay. I bought an intake manifold spacer through them last year.
      08 Lincoln Navigator L - 233k
      03 Mercury Marauder- 63k
        Note: These 4.6's don't produce a whole lot of low-end grunt with the carbed intakes....
        Gear up and converter up accordingly.
        Yep, that was a sad day.
          If you want to use it with the 4R70W transmission, Baumann Electronic Controls sells the Baumannator, which is a standalone controller for it.
            if its a hot rod, another option is just running a manual valve body
            or go 5spd
