So what can be done to CFI to increase HP? Besides replacing it!!
CFI performance
Changing the heads to a better design should help.86 Lincoln Town Car (Galactica).
Originally posted by Grand_Marquis_GT
Exhaust, a bump in timing...
As soon as this exhaust rots out I will go duals, maybe some salt water will help!!! :banana:
I read KN is only good for high revs and can cause other problems anyways.
Would better plugs and a stronger coil do any good?2000 Grand Marquis LS
Mercury Owners Group member
Originally posted by gadget73Changing the heads to a better design should help.2000 Grand Marquis LS
You should be able to change the heads without changing the computer to get some extra performance. Its not going to be a rocket but better flow=more power. Also like Tom said, good dual exhaust with headers will help too. Changing the rear to something like a 3.55 or a 3.73 also would be a good idea.86 Lincoln Town Car (Galactica).
how bout a carb swa.......sorry, never mind
yeah theres not much you can do besides better heads and exhaust without getting into a lot.
You could possibly swap in a CFI mustang cam and computer too... tweak the fuel pressure regulator and even have to throttle bores machined larger... but CFI will never see real power do to its itty bitty internal fuel rail.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
i would start with headers, h pipe, duals, and some gears.........3.55 is perfect for towing in drive
Originally posted by Grand_Marquis_GTNice avatar, ray!!
But didn't wanna be too over the top2000 Grand Marquis LS
Originally posted by IfixyawataI know of a guy who pulled the CFI body apart and removed the screens from the tops of the injectors and noticed that his car no longer had any off-idle hesitation. If you have the time to take the CFI body apart, it's worth a try.2000 Grand Marquis LS
