Tranny Fluid
    Tranny Fluid
    How often should you change the tranny fluid and filter on an AOD? I have a '91 GM and I'm looking to make my first change.
    1991 Grey Grand Marquis LS Sedan
    61,000 Miles
    1998 F150 XLT 4X2 Flareside Fire Engine Red
    52,000 Miles
    http://www.cardomain.com/id/hdlogistics
    61K miles, its about due.
    I usually do it every 30K, but I may be wrong..
      If you wait too long (past 85-100k) then it may be too late. It was too late for my '84 Cougar with only 65k when I changed it.
        but perhaps u should show how abused ur cougar was at 65K....
          For reference, here are the heads on my GM... 209k miles:
          Here, on the other hand, are the heads off of my '84 cougar. It had 70k miles or so when it died. In one day I lost 1st gear and the timing chain jumped a tooth:
          See, changing fluids IS important!
            Holy fuck!
              Well after seeing that, I'll be doing a change on the weekend.
              61,000 Miles
              52,000 Miles
                Just changed my tranny fluid & found the plastic plug in the pan. I guess that means that the fluid had never been changed since '91. The fluid looked a little dark but was shifting ok. Thought I'd better change it just in case. Seems to shift a bit smoother now. :jumpin:
                61,000 Miles
                52,000 Miles
                  i change my transmission fluid every 25.000 miles or two years, whichever comes first.........i use the same routine for cooling system service too
                  scott
