Cats
    Cats
    What is the law in ny regarding removing catalytic converters?
    (if this is in the wrong area, please move it)
    2004 Ford Crown Victoria P71 (Frost-Bite)
    2007 Chevy HHR
    it wont pass inspection in NY, its a visual inspection after 1984
    you can be sneaky and hollow them out, but you will need MIL eliminators or a custom tune so it doesnt trip a code, 96up have an obdII inspection where they scan the computer for codes and the self tests must run and pass, so you cant clear the codes and drive there and expect to pass. its done online, there is no way around it, unless you know someone, they can do the KOEO test to scan the vin, then quickly plug into the diagnostic port of a different car that passes KOER
      Thanks for the info. I kinda expected NY to be strict like California.
      2007 Chevy HHR
        Is there a point in removing stock cats unless they're plugged or you're upgrading to bigger pipes?
          cali and NYC are actually worse than what we have to deal with(the rest of NY state)
            i was just wondering. I have to stay legal for certain reasons...
            2007 Chevy HHR
              i bought a new set of cats for the Tank. The original cats were two pre-cats, and two cats.
              The new upgraded Walker design had only two cats. No pre-cats.
              That makes working around that part of the motor that much better because there's more room. Sweeeeedish.
              And NY sucks for that.
              08 Lincoln Navigator L - 233k
              03 Mercury Marauder- 63k
                ive never taken a car to emissions
                  Its only illegal if you get pinched for it.
                  You can buy converter 'shells' online to pass the visual, or hollow out the stock ones. O2 simulators, or a a call to your friendly neighborhood SCT (or similar) tuner will get you a tune, and the ability to cancel the downstream O2 sensor MIL caused by missing converters.
                  Now, I have also heard of stacking spark plug nonfoulers, and trapping steel wool between them, and then threading the O2 sensor into that as a way of fooling the MIL. You bore out one fouler, and thread the sensor into it. Pack the other fouler with steel wool, and thread the sensor into it. Then thread it all into the O2 bung. This pulls the sensor out of the exhaust stream, but still exposes it to the exhaust.
                  It works for alot of Dodge truck guys. Its cheap, and worth a try before you spend $300+ on custom tuning, or even $50 on O2 sims.
                    where can you get cat shells online? thats interesting...
                    if you do research, you can build your own MIL eliminator for like $5 with a resistor from radio shack
                      Can't any mechanic worth his salt smell that your car has no cats? My friend has bolt on cats in his car that he bolts on for inspection and then removes and bolts straight pipe in it's place. Im not sure how he gets around computer issues.
                      1985 GMC 1500
                        I honestly dont think most mechanics care, its more an issue of getting caught. I know NY, at least wny anyway, has undercover agents that take cars in to see if they catch people, I've heard of stupid stuff like missing rear seatbelts. the mechanic loses inspection license, faces serious fines, and even jailtime if thers an accident and someone is seriously injured or dies.
                        its just a visual inspection and an obd2 scan here, Im not from NYC, but they used to use a sniffer down there
                          (OP is from rochester, same rules as buffalo)
                            In NH you can get your car inspected pretty easily...... apparently all you need to do to get license is dance on your head and make funny faces or something. I'm not an idiot and I fix obvious safety hazards IE, brakes and front end components, but the silly stuff like emissions (which is just visual for cars as old as mine) I get by. I even know a guy who prints his own stickers..... Not sure I would want to get caught doing that.
                            1985 GMC 1500
                              I love living in ohio, ran off-road pipes on my mustangs for years.
                              Wrecked - Non-pi 1998 Mustang GT Best ET = 13.36@ 101
                              Just bought: 01 grand marq - 5th 4.6L and counting.
