Just throw the upper intake on? Just the new throttle body, EGR, and gasket? Also I think scott said he would weld up the tv cable holder thingy < very technical term I know, Anyways just want to make sure Im not missing anything?
What do I need to...
- Oct 2009
- 2878
- Keene NH
- Send PM
1985 GMC 1500
Tags: None
gaskets: upper plenum to lower, plenum to EGR, EGR to throttle body, and if you feel like it you could replace the gasket for the iac but if it's good then it's good
you need to swap the arms on the throttle bodies and bore the stock lopo EGR spacer to 63mm.sigpic
- Oct 2009
- 2878
- Keene NH
- Send PM
Alright, I have an HO EGR already that came with the new intake. I guess I'll get that glass beaded and contact scott at some point to weld up the throttle body arms."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
the mustang egr no workysigpic
- Oct 2009
- 2878
- Keene NH
- Send PM
Why is that?"Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
- Oct 2009
- 2878
- Keene NH
- Send PM
Originally posted by andymac0035 View Postit's plumbing is laid out diiferenlty because it's designed to face the other way"Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
- Oct 2009
- 2878
- Keene NH
- Send PM
Yeah Ill go snag that at some point here, supposed to rain the next 2 days."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
You can use mustang egr or egr delete just have to modify the throttle cable bracket. I have a mustang egr delete on mine only took about 30 min to modify. But since it seems you dont have a welder stick with the stock one and get it bored.
'90 LX 5.0 mustang
Big plans
- Oct 2009
- 2878
- Keene NH
- Send PM
Yeah, have a welder, don't know how to weld.... I should get on that."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
