Don't take my opinion as true... but I think the lopo is identical to the HO besides the heads, cam, and intake. Like I said, I may be wrong or most likely wrong.
What I meant is how much hp/tq can a lopo block take before it splits? Will a main bearing girdle help things? Just curious during this quiet day at work.
From what I've heard, the lopo block is one of the stronger blocks to build up a 302 from...
1984 Ford Crown Vic LTD, The Murphmobile (RIP) 1985 Ford Crown Vic LTD, The Murph Deuce (SOLD)
500+ hp is where you run into problems with the block not being able to handle it
~500hp the block quits at. If you had HO pistons, the bottom end will hold up to anything that the block will tolerate. Theres no need to fancy up the bottom end unless you plan on rpms over 6000 or so. Honestly I'd do any real build with an HO shortblock just for that reason, or replace the stock pistons and carry on.
So with a decent bottom end build, a TrickFlow Street Burner engine kit, and whatever supporting mods, you think it will hold up?
this is actually what I am planning on doing, just find a 5.0 (doesn't matter which one), have it punched to 306 (piston problem solved), up the compression a bit, and run the Street Burner Engine kit.
In the end it should be about a 3k build, with netting close to 400hp-ish
I was thinking more along the lines of what to do with a lopo after a swap. 500rwhp and we're cleaning the sheets. Okay, nice tidbit of info. Thanks guys.
about 400-500hp just like the HO.. once you get into the 400hp range your pushing it.
