C6 to AOD swap
    C6 to AOD swap
    I have a 76 Mercury marquis with the stock C6 trans and 6.6L engine. I was wondering if any one here has done a swap to replace the C6 with an AOD. If so where did you get your trans and did you have any complications with fitting it.
    Won't bolt up. The AOD is a smallblock bolt pattern and the 400 is a big block pattern. There may exist some adapter plate, but I'm not sure about that. You could do an E4OD trans with an electronic controller, or a Gear Vendors overdrive unit behind the C6.
      this adapter will do but at $795
