Anyway most of them seem to be carbed intake. How much work is it to switch over to this setup in a 91 with EFI? I would like to stay EFI, but I was just wondering.
Looking at some crate motors...
- Oct 2009
- 2878
- Keene NH
- Send PM
1985 GMC 1500
Tags: None
Remove carb intake. Put on EFI intake.
I'm sure there's some good long blocks though that are probably a little cheaper.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
^^this. The bolt pattern is identical, so no special magic to swap to an EFI manifold. The only thing you really need to know is if its a roller cam or a flat cam, because that affects the distributor gear.86 Lincoln Town Car (Galactica).
they're plenty interchangeable. a guy i know was getting shitty mileage with his EFI town car and he's used to working on carbs so he tore the efi stuff out and put a 4bbl on. i think he did it backwards but that's just mesigpic
- Oct 2009
- 2878
- Keene NH
- Send PM
I see, I was just worried about wiring, I knew the bolt patterns would be the same. It just seems to be kind of a waste to buy a crate engine then drop another grand on an efi intake for it.... I will see what happens."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
those crate engines are way overpriced.......better off building your own
Originally posted by 91grandmarquis View PostAnyway most of them seem to be carbed intake. How much work is it to switch over to this setup in a 91 with EFI? I would like to stay EFI, but I was just wondering.
2. The problem with buying a crate motor is that if you buy a long block, unless they specifically offer an EFI-friendly camshaft (around a 114 or so LSA, EFI works better with good vacuum signal), a lot of these aren't really friendly to EFI.
3. My recommendation? Buy a built short block, and add the remaining parts. With what I'm seeing from local machine shops, and the exorbitant prices they charge for machine work, in nasty, dirty shops, if you do your homework on a short block, you'll come out about even, and the bottom half will already be assembled.
4. The only sticking point to this route is that you'll need to ensure that the heads are torqued down correctly, and that you have pushrod length/rocker geometry checked by someone proficient in that particular endeavor.
- Oct 2009
- 2878
- Keene NH
- Send PM
Well I was looking into it because of the warranty on a pre assembled engine is all. From what I have seen Ford Racing seems to be some of the cheaper ones I have found, maybe I am looking in the wrong spot though. Im considering either a 302/351 shortblock."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Check out www.fordstrokers.com there liberator short blocks are a steal for the quality of work he puts into them.You can also buy a do it your self liberator completly machine block and rotating assembly you just put it together, that will save you even more money. And the owner is a straight shooter with good customer service.
'90 LX 5.0 mustang
Big plans
Originally posted by 1980c10 View PostCheck out www.fordstrokers.com there liberator short blocks are a steal for the quality of work he puts into them.You can also buy a do it your self liberator completly machine block and rotating assembly you just put it together, that will save you even more money. And the owner is a straight shooter with good customer service.
