Are there any long tube headers that would fit my '87 MGM?
Long tube headers
Long tube headers
COBRA 25LTD CB with/ Wilson 500 whip antenna.Tags: None
- Oct 2009
- 2878
- Keene NH
- Send PM
as far as I know the problem is the trans housing not having enough room to squeeze em by."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
If only there were....2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
- Oct 2009
- 2878
- Keene NH
- Send PM
I am sure with enough $$ you could have some custom made..."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Floor shift + cut off wheel+ welder = longer headers in a pantherhttp://secondhandracing.com/Home.aspx
Originally posted by DuceAnAHalf View Postcut off wheel+ welder1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
Originally posted by Pesty351 View PostFor what the fire wall?http://secondhandracing.com/Home.aspx
What detriments do long headers have (hp, torque)?sigpic
longtubes pretty much always make alot more bottom end torque and midrange, and in alot of cases, more top end as well, the biggest gains are bottom end and midrange
less drone at part throttle, but louder at WOT, harder to remove transmission in most cases
Originally posted by jayh View Postlongtubes pretty much always make alot more bottom end torque and midrange, and in alot of cases, more top end as well, the biggest gains are bottom end and midrange1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
Originally posted by Pesty351 View PostI always thought it was the complete opposite of that. I was told shorties are better for the low end and longs were for up top.
That is why short-tube headers are kind of pointless vs. long-tube setups, they don't start working until WAY up there in RPM range.
Hmmmm......
..Gets out welder and cut off wheel......1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
