22c plugs and 180 thermostat
    for my tbird.
    what is the benefit?
    Not much.
    Plugs will foul sooner
    The engine will run a little cooler.
    -Michael
      not neccessarily, depends on the mods, or calibration, I run a 180 in every vic I have and still have heat in winter, cooler summer operation, and crap that you will have closed loop issues is garbage.
        Well the t bird is stock.
        -Michael
          All it has is a freer flowing exhaust and intake...
            i wouldnt bother unless you have a very aggressive computer tune with some timing advance.
            2000 Mercury Grand Marquis LS HPP.
            http://www.cardomain.com/ride/2336322
            Friends don't let friends drive donk.
              I find that the Mark runs better and does better on gas with those same mods (Autolite 103, actually). I'm not on the gas too much, better throttle response, and I gained 2 MPG.
                most mod motors i've seen have lost mpg swapping colder like that.
                  Probably because once you notice the extra power, the full-throttling resumes... :evil:
                    I should really concentrate on beefing the merk up, but this car is too fun!
                      ruh-roh!
                      tom's hooked
                      Save a seal, club a liberal.
                        Remember what you have learned, feel don't think. Be mindfull of the dark side, easy is it to take.
                          The thermostat is fine but the plugs aren't necessary unless you have a different tune. Now if you get a steeda timing adjuster and crank it up then yes. See, 4.6 ain't all that bad. J-mod the tranny :evil:
                            Do you have any experience with the timming adjuster?
                            -Michael
                              I was thinking bout the ASP pulleys and the timing adjuster.
                              Teh JMod is next on the list :evil:
