Post your suspension setup
    I'll go first
    89 Country Squire LX
    PI rear bar
    1 3/16" front bar
    Poly sway bar bushings and HD endlinks. (Advance Auto replacements)
    Mustang Bullitt wheels w/ 1" adapters
    Plans:
    1000lb/in Springs (front)
    Street Stock Shocks
    92+ front control arms/spindles w/ poly bushings
    98-02 front brakes
    95 Towncar rear discs
    VAPS (Variable Assist Power Steering) Manually controlled
    Higher rate rear spings
    Adj rear street stock shocks
    Higher ratio steering box from newer PI
    Frame reinforcements F&R
    Driveshaft loop
    86 Towncar
    Stock original everything
    Monroe air shocks in the back
    replacement stock endlinks from NAPA
    Plans:
    install the KYB front shocks I've had for 4 months
    install the rear carg coils I've had for 2 months
    install the rear sway bar I've had for almost 3 months
    install the other 4 rear control arm bushings
    eventually new PI front springs
    front brake upgrade
    wagon or PI front bar
      P71 HAP (HH) Springs
      ADDCO 1" Rear Stabilizer Bar
      Stock 28.5mm Front Stabilizer Bar
      ENS Polyurethane Bushings and Endlinks
      -Michael
        the 85
        now.
        front springs PI springs with coil removed rate is about 825 in/lbs.
        Carrera street stock shocks with #8 valving and 550 of dampning. Wagon front sway bar
        rear EE springs, no shocks, boxed lower control arms. PI bar once i clerance the arms.
        Future plans.
        front. 96-97 spindles, Delrin bushings (having the uppers machined now), Wilwood 4-piston calipers with a 12" rotor
        rear torque-arm with a Watts-link and coil-over shocks. civilian sway bar
          86 Crown Vic;
          1-1/8" Front Sway Bar,
          1" Rear Swat Bar,
          HD Police Rear Springs,
          New Factory Front Springs,
          Solid Screw Upper control arm bushing,
          Some nice front shock, I forget....
          Generic Rear Air Shocks,
          11" Police Rear Dum Brakes,
          Larger Police Disk Brakes in front,
          Motorcraft Police Pads,
          Near plans; (Less than 2 months)
          Full set of 15"X8.5" Western wheels, they are waiting for some rubber.
          New tires 2 X 265/55/R15 and 2 X 245/55/15, If I can find those sizes I don't think so though
            Originally posted by Blaze86Vic
            86 Crown Vic;
            1" Rear Swat Bar,
            Larger police brakes? IIRC only the calipers are different, they use a larger 70mm metal piston and different pads. The caliper is the same as used on the Mark 7's and Mustang SVO. (from what I could tell) The rear drums are definately larger, 11"x 1.5 or 2" The towing package/PI/ wagons shared those rear brakes.
              my suspension is stock
              Save a seal, club a liberal.
                you suck, get out LOL
                  can't touch me. i got diplmatic immunity and go where i please
                    "Im just like that guy in Lethal Weapon 2"
                      Stock 2000 P71 Suspension which is better then a civilian.
                        Yeah you're right, just calipers. It's 2" drums I believe, though I could be wrong on that too.
                          Moog sedan cargo coil springs on all four
                          Monroe Sensatrac shocks in back
                          KYB GR2 shocks in front
                          Stock front sway bar
                          1" rear PI sway bar
                          If it's possible to find polyurethane bushings, the front and rear ends will get rebuilt.
                          Btw, I'll remind everyone of www.p-s-t.com, just in case they have something for us. I haven't had a chance to call them, yet.
                            http://www.stockcarproducts.com
                            For springs and shocks. They also have rear control arms that might be able to be used on our cars. Gotta call them and take some measurements of the rear arms...too bad I do not have a apare set to measure...
                              Got:
                              Rear air shocks (don't know brand)
                              Future plans:
                              KYB front shocks
                              Rear sway bar
