some cam info i came across
    hey there mangs i came across some cam info that i thought might be helpful for you.
    (found at ford-trucks.com)(I do not not know for sure,but i think the author may have goofed ona few of the numbers.)
    For the record here a few roller cams that are known to work well with Speed Density EECIV. Generally durations below 216/220.
    ........Cam # .............Lobe Cent....... Dur@.050...... Adv Dur.... Lift@valve
    CompCams 35-510-8........112............ 208/216........ 258/266..... 533/544
    Crane 444211..................112............ 208/216........ 262/270..... 530/530
    CompCams 35-308-8........114............ 210/215........ 266/270..... 533/533
    Crower 15510..................112............ 212/212.........275/275..... 531/531
    CompCams 35-349-8........ 114............ 212/218....... 264/270...... 512/512
    CompCams 35-310-8........ 114............ 215/220....... 270/276...... 533/544
    Crane 444211.................. 112............ 216/220....... 270/278...... 533/544
    OEM 5.0HO..................... 115.............211/211....... 266/266...... 444/444
    These cams below work with SD, but run rough and require more tuning(chip).
    CompCams 35-305-8......... 114............ 215/225....... 270/284...... 533/533
    CompCams 35-351-8......... 114............ 218/224....... 270/276...... 512/512
    Crower 15511.................. 114............. 218/224....... 278/282...... 468/486
    __________________
