5.8 Swap in the works, questions.
    I was originally planning an EFI 306 build, but ever since my latest discovery, I'm leaning towards carb 351.
    I recently came across a local yard that has a 85 Cop Car 351 with 88,000 miles on it, and they want 350 for it. Once I get the money, it will most likely be mine.
    Question 1 is Did the 351's have the same crap style pistons that lo-pos did, or do they have different ones (mainly worried about cam lift at this point)
    Even if there is clearance, should I replace the pistons anyway to up the compression a bit?
    The goal is to get the Edelbrock power package which is good for 400hp and 450tq, which is why I'm opting for a cop car block vs And F150 roller block (the eddy kit comes with a flat tappet cam).
    Other Questions:
    Fuel System....should I just opt for most of the cop car components, with an upgraded fuel pump?
    Ignition....Will the TFI work? Or will I have to shitcan all of that too
    What do I do about the computer?
    Anything else a major obstacle that I need to take into consideration before this? I'm not expecting this to be too entirely easy, but I'm not expecting it to be hard either.
    The 351 build will net me more power for less dough vs the 306 (a parts tally for the 306 had me at 5k to only get about less power than the 351, so I quit counting lol) Any input on this will be greatly appreciated. Now I just need moneyz....
    Very nice!!! Do what ya gotta do to get the money (even if that includes trickin on Friday nights).
      thanks...I don't expect it to come all at once either. I most likely will get the engine and gradually build it up. I also need an 89-up AOD to build up, and I'm planning on a 3.55 trac Lok rear end build. This has the potential to be a good summer.
        Sounds a lot like the build I am plannin for my 87. Carbed 351 (might be crazy, might be mild, havent decided yet :smirk built AOD, and posi rear.
        To attempt to answer some of your questions I think your prob gonna need to trash everything to do with the fuel injection. Also I know that for the ingnition most guys run an MSD box when they do a carb swap.
        -2004 Crown Victoria Police Interceptor - Daily Driver - 17" Bullitt's, 235/55/17 Goodyear Eagles, Ex-NH State Police, best 1/4 mile time; 15.3 @ 90 mph
        -1987 Crown Victoria 2-Door - Project - 90k miles, Summit chambered muffler, Sunpro gauges, parked since 2010, fate tbd
          just take all your computer stuff out. If its carbed you might need to get the tank out of the donor car, since it will use a mechanicle pump located on the timeing cover
          1980 Lincoln Continental Mark VI Signature Series
          351 4 bbl, AOD, 3.08 open
          duel exhaust with cherry bombs
            Why not keep your EFI? Almost everything will swap- wiring, mounts, fuel system (upgrade pump,) etc. Just need to find an EFI intake (Lightning or TFS,) convert to MAF HO ECM, and get the exhaust modified to fit. Much easier than converting the fuel system and ignition.
              you can run a flat tappet in a roller block, no problem there
              for the money, you can get a better head for what the edelbrock would cost
              keeping efi isnt a horrible idea, Id skip the gt40 intake though and use edelbrock or tfs
              Im pretty sure the 351 uses cast pistons; notching pistons isnt that big of a deal either
                What exactly is a "roller block"?? Sorry for going off topic.
                  Just grab the pickup out of the tank, is all.
                    I agree on all points. I'd go Edelbrock or TFS before GT40 unless you get a smoking deal ($350 or less) on the GT40 intake.
                    Either way, good luck.
                      If you can find a motor out of a 94+ truck, get that instead, its a roller motor. I think those also have hyper pistons, though I may be wrong there.
                      The police motors have big oval dishes in the middle. I suppose they work for valve reliefs, but they also have the effect of tanking the compression pretty badly. I think they're also a craptacular cast piston, so they're not worth much anyway.
                        the valley is tapped for the hold down for the dog bones and the lifter bores are taller; allows the use of a hydraulic roller cam with stock roller lifters like your 302 has
                          compression ratio is 8.3 to 1 on stock police motors. that + cast pistons means that a set of pistons would be high on my list if I ever pull my engine for a refresh.
                          something like this:
                          http://www.summitracing.com/parts/FEM-MHP176-300/
                          would end up with you gaining a good amount of compression for a couple hundred bucks when you factor in the money you would have spent on the rest of that kit anyways.
                          If you want to go bulletproof, another hundred or so gets you forged pistons http://www.summitracing.com/parts/FEM-CSMHP803-000/
                            Go for the roller block and cam. Better profile, less friction, and a lot easier to break in.
                              My main concern about keeping EFI is cost. Also hood clearance issues. I believe I am correct in saying that the TFS manifold will not fit under the stock hood, and the Lightning intake is a little pricey, and I'm not too thrilled about a super victor plus an elbow either unless there is some serious power backing it up. Plus than you have to think about healthier fuel injectors, a tune, and other electronic crap, when I can get the same amount of power out of a carbed motor.
