when i start my car in the morning all is fine and dandy running at 14.2 volts ish but after the car heats up it struggles to maintain 13.2 volts during the day
i had to take a 4 hour drive on monday only thing on was head lights and a/c i was only getting about 12.2 volts give or take finally i had to deal with the heat because my headlights were too dim
i have been to three auto parts stores today had alt starter and battery tested every store came back with an A+
im at a loss here guys
im thinking this weekend i have access to a 00 vic can i swap that alt in and se if it does the same thing?
new belt and tensioner less than 10k ago
i know i have a big radio but i dont run it right now because of the issue at least not at night
joe i also have had two dealerships test it
i have access to a 2000 crown vic is it the same alt i can swap it out and se if the car does the same thing
as far as for the wire my amp pulls less than 65 amps on the average its very efficent i ran this system in my regal with a 90 amp alt no issue
the wires are 4 guage for power and ground
no big three yet am working on it but i need to figure out how long the starter cable is cause i wanna replace that one too. and i am still slightly confused on what/where to run wires
also i was looking at
its a 200amp compared to my 135 this should work correct
but my terminals do look good no frays very lill crossion on the pos the metal is slightly discolored not covered in crud
what would some of the best terminals be?
like this morning i started the car i had 14.5V held strong for about 8 miles then droped to 14.0V still good but a lill lower than i would like, then when i went through the drive through at the bank it droped to 13.2V when i parked it my car was on for about a half hour.
it seems the warmer it gets the lower the voltage goes but if it ever gets to low i can just put it in neutral and the voltage comes right back up?
is there a seperate way to test just the voltage regulator
any other ideas please help
also I have thread on other panther form here if you want to se some of the response I have already answerd to I only copied my stuff from there
thanks for the help guys
EDIT: sorry thought i had set up a sig
02 grand marquis throttle body space, k&n drop in , big steves $6.00 cai, custom led's, eclipse front speakers blocked, alpine type r rear speakers, eclipse head unit and two Kicker CVR's powerd by Eclipse da 6213 amp
