302 carb..help me out
    will remote start up work on carburetor, i switch my car from a fuel injected to carb but my remote start doesnt cooperate.
    And what is the best way to star the car pat the gas firsr then start it or........
    carbs generally like a single stomp on the gas to prime them first for a cold start.trying to crank it cold without a prime usually results in endless cranking.
      one or two pumps to get some gas in the intake and set the choke is what its gonna take. It may also require adjustment of the choke, the high idle, and the fuel mix screws to make things happy. I wouldn't expect the remote start to work very well on a carb at all.
        There might be something you can rig up concerning a....nah, never mind.
          Lol ok now one more qustion after a while of running the car will just shut off and its like gas isnt getting to the carb and i have an external pump in the hood . So is it to much gas where its flooding it out or do i need to remove the fuel pump out of the tank.. Theres really no good performance mechanics in houston so thats wh im having all these problems.
            External electric, or external mechanical? Is this pump under the hood? Just for future reference, absolutely none of the electrical fuel pumps out there work that far away from the gas tank. Electric fuel pumps are primarily a 'pusher', not a puller, in that they need to be really close to the fuel source in order to work properly. If someone tossed in an electrical pump in a 10-minute butcher job under the hood just to get the car running, the pump usually doesn't last very long up there.
            If it's a mechanical pump....I have a couple of ideas, but I want to hear what kind of pump is in it first.
              while probably not cheap, I have a hard time beleiving there isnt a good performance shop in a big city like Houston
                it have a couple of performance shops but not performance mechanics
                  u sayin exactly wat some1 else told me. so what kind of fuel pump will b good and where should i install it????
                    Which pump do you have installed right now?
                      actuallly im not sure its a small gold electric pump
                        If you have an electric pump, it needs to be moved at close as possible to the gas tank, and mounted as low as possible. I'd also considering installing a basic 30-amp relay to fire off the pump, in case one hasn't been installed already. I don't know how this gold pump of yours is triggered, so this needs to be determined before you get too carried away.
                          ok so ill move it to the back. but wouldnt i have 2 rig a hose or somethin n the tank
                            I have no idea as to how the existing fuel system is set up. Typically, some fuel system modification is required to mount an external fuel pump back there, so yes, you'll probably have to rig a hose, and add some wiring.
                              ok thanks im goin to get it done tomorrow morning ill let u know the results
