I know some of you have either converted ATC to manual, or pulled your A/C. I am looking for any servo units you might want to sell. Thanks!
ATC Parts?
ATC Parts?
sigpic'86 GM LS sedan bone stock 113k triple dark sable, most of the bells and whistles, second owner. SOLD 9/10, will be looking for an 89 TC when the time is right
"In order to know virtue, we must first acquaint ourselves with vice" Marquis de SadeTags: None
I have the original vacuum controller (blend door lever actuator) for the ATC from my 88 if it's the same and needed. I replaced that trying to hunt down the issue with the system (vacuum leak somewhere) and it turned out that it was the check valve engine bay side of the firewall. The controller works fine, though it's a little slower (factor of half a second... ish so not that much slower, but being the detailed oriented person I am, I did notice) than the new one on the switching (may have smaller or dirty channels since it's original).
I have a complete ATC heater box from my 88 MGM.....2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
sure it's the servos, i just fixed a atc system a little while ago, the vac line under the hood was broken off
Originally posted by slymer View PostI have the original vacuum controller (blend door lever actuator) for the ATC from my 88 if it's the same and needed. I replaced that trying to hunt down the issue with the system (vacuum leak somewhere) and it turned out that it was the check valve engine bay side of the firewall. The controller works fine, though it's a little slower (factor of half a second... ish so not that much slower, but being the detailed oriented person I am, I did notice) than the new one on the switching (may have smaller or dirty channels since it's original).
Craigsigpic'86 GM LS sedan bone stock 113k triple dark sable, most of the bells and whistles, second owner. SOLD 9/10, will be looking for an 89 TC when the time is right
Originally posted by 88grandmarq View PostI have a complete ATC heater box from my 88 MGM.....sigpic'86 GM LS sedan bone stock 113k triple dark sable, most of the bells and whistles, second owner. SOLD 9/10, will be looking for an 89 TC when the time is right
Originally posted by cadfan64 View PostThis is the servo, correct, with the big vac line from the sensor, and it has the auto blower switch and another vacumn valve? What were u asking for it, shipped to 43506? Thanks
Craig
the part that has the massive amount of vacuum lines plugged into the side of it and the electrical connector plugged in the end that the vent lever on the control panel slots into. This is the "brain" of the ATC system. $20 shipped.
Originally posted by slymer View Postmotorcraft part YH-378
the part that has the massive amount of vacuum lines plugged into the side of it and the electrical connector plugged in the end that the vent lever on the control panel slots into. This is the "brain" of the ATC system. $20 shipped.sigpic'86 GM LS sedan bone stock 113k triple dark sable, most of the bells and whistles, second owner. SOLD 9/10, will be looking for an 89 TC when the time is right
Originally posted by Lincolnmania View Postsure it's the servos, i just fixed a atc system a little while ago, the vac line under the hood was broken offsigpic'86 GM LS sedan bone stock 113k triple dark sable, most of the bells and whistles, second owner. SOLD 9/10, will be looking for an 89 TC when the time is right
:bump:
still looking. This is the part behind the glovebox that hooks to the blend door, has a vacumn hose from the sensor, another vacumn valve and the auto blower switch on it. Anyone?sigpic'86 GM LS sedan bone stock 113k triple dark sable, most of the bells and whistles, second owner. SOLD 9/10, will be looking for an 89 TC when the time is right
damn it ... I knew I forgot to do something.
I will drag the ATC stuff out tomorrow and check it out for you.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
