aod not shifting
    aod not shifting
    I'm guessing that there is something messed up in the valvebody.
    The car ('87 CV CS) hasn't been driven in about a week, this morning it
    seemed to stay in 1st too long, then stopped shifting entirely. It sometimes
    felt like it oozed into 2nd. The slightest pressure on the pedal switched back to 1st.
    Manually shifting made no difference.
    About a month ago I installed a Transgo
    aodhp kit & a B&M 'vertor. The lines & cooler were flushed. It was making me late
    for work so I switched to the GM CP. I didn't have time to check the fluid. No
    evidence of a leak where it was parked though. Sorry if the formatting is
    goofy, sent from my phone......
    Is the TV cable working properly? if it stuck and you're running at full pressure it won't upshift correctly. I'd also check the bushing and the fluid level.
      Thanks for the info, I will check the cable & fluid level tomorrow before work.....
