97 CV A-frame bushings
    Does anybody know how hard or easy it is to change out upper control arm bushings on a 97?. I've been told you need a lift, can't do it with jack stands. And that they will need to be pressed in, is that true?
    Anybody done this?
    I've got to get on these fast, front end noise driving my crazy
    Thanks,
    you do not need a lift
    you do not need a press either if you replace the rubber bushings with poly
    gotta run out rescue a broken vic, more later
      I finally got into the 97's front end, and decided to replace the control arms and not just the bushings. It needed ball joints too and brakes!! The new control arms where cheaper than bushings and ball joints for the old ones. This job looks tough but it is incredibly easy, the thing just came apart, both sides out in 45 minutes to an hour at most. And that is doing it for the first time. Changed out the cracked plastic intake and valve cover gaskets as well.
        Cool. Suspension work is generally not as horrible as people make it out to be. The only thing I'd suggest is checking the stuff on the lower arms. Generally the lowers take more abuse, so if the upper ball joints and bushings were shot, I wouldn't expect the lowers to be much better.
          ok... i am working on a 1992 Grand Marquis... the rear upper bushings are shot on both side and banging metal... the passenger upper ball joint is bouncing too...
          where do i get the poly bushings from.. i looked up autozone, oreilly and advance ...
          none have the poly except autozone which is red bushings and full kit costing $71.99 for all the bushings and i dont need them all
          Addicted to 86-87 Panthers
            energy suspension sells the kit, but its for all 8 bushings. Honestly if your uppers are that bad, yes you do need all the bushings. The lowers are going to be right behind the uppers, and both uppers should be done at the same time. Also if the upper ball joint is shot, almost guaranteed the lowers are wasted. They typically wear out long before the uppers do.
              keep in mind and this may be just my experience but I had poly bushings on a truck once and I got a lot of squeak the rubber didn't have. The poly are superior but you might want to lube them with something every so often to remove squeak if you get it.
                you have to slather a lot of that sticky nasty greasse they come with on the bushing to keep them silent. Mine don't make noise, but I lubed the BS out of them during install.
                  Is there any real difference between police and non-police front upper a-arm bushings? And if so which is better? I expect police? Working on a 94CV.
                    police should have a solid upper control arm...no bushings in there
                    -Phil
                      the solid bushing nonsense stopped in 92. The later police arms have different sized bushings though, I think they're both the same size vs the Civi arms with one big, and one small. You cannot put police bushings in a non-police arm.
                        i have one pi 92-94 upper arm and one non pi 92-94 pi upper arm on my town car big brake conversion, i did not know about the es bushings in 04, the grand marquis i pulled the upper arms from had an arm replaced with a pi arm and i did not notice, was a bit of bushing confusion, but it all had to go together in a weekend.......should have a pr of matching upper arms cause you would not want to have to order two poly busing sets......there is no real difference in handling is what i'm trying to say
                          IIRC my towncar had p71 uppers because they were two different sizes and the civi is all the same. I ordered civi bushings so I dunno. Been too long. However I did get my rear poly bushings in this weekend.
                            mah bad...i'm too old school lol
                            -Phil
                              Well, you can, after doing my sandpaper-on-a-lathe routine, but it'd be lots easier to get the right bushings to start with. I bought the 4.3153 by mistake for box-body civilian arms and two bushings were too big.
                              I bought extra grease when I ordered the bushings just because. I don't recall having much left over.
