Hello guys in my quest to learn more about cams I would like to pick everyones brain.
As I plan my build for my vic I am looking at cams to get monster torque off the line and across the RPMS here is my ??
What makes a cam a torque cam? is it duration? lift? the power band the cam will work in? I know all these play a factor but I see so many cams that have similar numbers but the are listed at differnt power bands some say like .448 .472 power from 800-4500, then I will see a similar cam that says its good till 5500 same with intakes.
I guess what I am saying is, is there a duration and lift that makes more trque down low and is there a cutoff like once I get to .500ish do i consider that a cutoof for torque cams?
