1994 GM - Airbag light - Code 15
    Getting a code 15 from the airbag light on my '94 GM. I looked around and found this
    No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure)
    From my understanding if there is no voltage on pin 1 when the key is turned off, there is no power to the KAM.
    Could this possibly be a blown fuse or something? I know the lighter fuse is blown, and has been for a while now. Could that be related?
    Any idea on the easiest fix, next to swapping out PCM (hope it don't come to that). Wife is very worried the airbag is going to go off for no reason.
    Thanks
    Bass Race Competitor - 140.0 - 149.9 class
    Tech Systems 12volt Audio and Accessories
    GroundPounderzInc Sales Rep for Florida and Georgia areas.
    Update on this, since no one has answered.
    Still have the blinking. I have checked all the fuses and none are blown. I sort of have a feeling the front sensor is bad, but not sure if that would send the code I got.
    blink pause blink5x. That is 15, correct? I can't figure it out and really just want to disconnect the light, but can't. She'd probably kill me
      You can remove the airbag fuse for now if you want. Lemme check some stuff.....
      08 Lincoln Navigator L - 233k
      03 Mercury Marauder- 63k
        If the airbag light is on, the airbag will not deploy. They're designed so that if the airbag module detects a fault, it disables the system. Otherwise there would be lots of litigation. Tell your wife not to worry.
          I tried to look up some info and I couldn't find a code 15 for that year panther. I am not calling you a liar I m just saying I couldn't find the info for it.
