View Full Version : Rear Springs?
nitroracer
09-20-2005, 02:20 PM
What are the different rear springs availbale for boxes? Do they differ bewteen make and model or both - lincoln vs ford or wagon vs. sedan.
I'm looking for slightly stiffer springs but not the huge rake associated with wagon cargo coils. Would stock wagon springs do what I'm looking for? And where can you buy them from, I don't see any listed online.
Grand Marquis GT
09-20-2005, 02:23 PM
You know you want the rake!
I hear stock sedan cargo coils are plenty enough... And from what i've seen... That is true. And you will be running regular shocks, right?
I suggest getting some KYB GR-2s on all four corners..
RugerP97DC
09-20-2005, 02:54 PM
Edelbrock IAS!!!!!
Can I get a w00t!!!!
mrltd
09-20-2005, 03:12 PM
If you are going for handling, don't get the cargo coils. Get some PI rears or get some circle track ones. Wagon springs will give you a rake. The rates are posted in the FAQ and there is some more info in the one thread by Deuce...
mrltd
09-20-2005, 03:24 PM
This thread has some good info on autocrossing a box...
http://www.corral.net/forums/showthread.php?t=637169&page=1&pp=35
gadget73
09-21-2005, 12:51 AM
New cargo coils on my car didn't give it any rake. It sits just about level unless I pump some air into it. Ride is no stiffer than before, but the old springs were toast and I ran 100 psi of air to keep the car mostly level.
Blaze86Vic
09-21-2005, 06:13 AM
Yes, but you are in a lincoln with a ton of stuff in the trunk ;-)
I have PI rear springs, now that I see I have more option in the front, I thinl I'm going to be getting either 800 or 900lbs/in for the front
DuceAnAHalf
09-21-2005, 07:21 AM
Pi front springs with one half coil removed give you about 825 in/lbs.
if i remember to borrow the book ill post the coil spring rate formula
Grand Marquis GT
09-21-2005, 11:19 AM
with airshocks in the rear with 25psi, my cargo coils and rear bar, i hauled my 351W home from GA in the trunk of the merk, and the rake didnt change at ALL.
The 84 HD Cargo coils for a colony park are the best coils for that killer rake...
http://www.grandmarq.net/images/work%20004.jpg
nitroracer
09-21-2005, 04:50 PM
My car is air shock-less, probably has the original 91' shocks on it too. I was thinking a set of PI springs for all corners or maybe the limo springs that are rated inbetween.
Front Springs
Load Rates in Newton Meters & ft/bs
Stock: 77.1 - 440lb
Limo/HPP: 98.1 - 560lb
Police: 122.6 - 700lb
**Correction I just read HPP rear spings cannot be used on my box due to them being setup to be run with the factory air springs**
So how does police springs out back and HPP springs up front sound for a good handling daily driver?
I'm getting PI (160lb.) or custom (190-200lb.) springs. I want to firm up the suspension and get rid of the "retirement home" ride. This boat is going to be a cigarette boat!!!!
mrltd
09-22-2005, 05:38 PM
Why buy custom? You can get the springs... Circle track parts! Almost any rate you want. Double pigtail springs. 175lb-300 in 25lb increments.
DuceAnAHalf
09-22-2005, 05:43 PM
:stupid: you can get springs for all 4 corners for about $200 plus shipping when coilsprings.com wants $130 for 2. check my thread at the top of this forum for springs.
mrltd
09-22-2005, 06:33 PM
You should be a mod... :D
Grand Marquis GT
09-22-2005, 09:01 PM
Want the job??
DuceAnAHalf
09-22-2005, 09:39 PM
if you feel that im up to the task. i will accept it
Grand Marquis GT
09-23-2005, 07:49 AM
Welcome aboard!!
DuceAnAHalf
09-23-2005, 03:45 PM
:slug:
Thanks for the info. I was going to use www.coilsprings.com, but the circle track springs look good.
Fairmont Kevin
09-24-2005, 09:25 AM
Front and rear spring rates should be matched. Don't use PI springs in the rear and race springs 200 lb heavier than PI springs in front. A 900lb race spring is 29% stiffer than a PI front spring. You should use a 29% heavier rear spring, ~210 lb.
But then you need matched shocks or you won't be able to control the body motions properly. I was thinking about race springs but I don't want to buy really expensive shocks. I think I'll stick with PI springs and shocks. Unless some circle track shocks will fit, work well on the street and not cost a fortune. I'll look into that...
NATEHAWK
09-24-2005, 10:25 AM
I think Blaze should be a mod :clap: :clap: :clap:
DuceAnAHalf
09-24-2005, 01:36 PM
Kevin check this link. Carrera makes street stock shocks that bolt up to a box-body, they even have it listed as an application. Linky (http://www.grandmarq.net/forum/viewtopic.php?t=4199)
mrltd
09-25-2005, 03:39 PM
Kevin, with all of my cars, even with the HD Moogs front and back, the front still was undersprung. And with HD shocks it bounced way too much. The chunks of steel missing from the crossmember of he 87 proved that well... With my wagon it's even worse. The rear is so stiff it doesn't move and the front just bounces. The shocks are all new motorcraft replacements. Check out the pics of my autocross and the vid...
Circle track shocks fit fine, a few people have used them. Once i get some more money together I'm getign the 1000lb springs and the SS shocks. I know with the wagon, that the rears should be fine for now. I'll have to see how balanced it is. I'm also looking in to making the rear bar mount differently and have adjustment.
sniper308
10-04-2005, 08:40 AM
:cop: Hmmmm,very interesting I want to change the rear springs to my Panther but ¿the best recomended it will be to change the 4 stock for 4 P.I. sprnings? :3gears:
ATT.SNIPER 308(PROUD OWNER OF "BLACKHAWK-P74 INTERCEPTOR") :cops:
