throttle body
    throttle body
    Im currently looking for a throttle body but isn't having any good luck. The build is a rebuilt 93 mustang with a gt40 intake&heads(off a 96 ford explorer), ford racing E303 cam, & also with the mass air setup. I was looking for a ford lightning oem throttle body but it seems like they dont exist...
    Why not use the throttle body from the Explorer? thats what I did!
      use an explorer 5.0 throttle body, they are 65mm, same as the lightning, you just need to swap the levers over
        What they said. Explorer TBs are fairly obtainable. The magic Lightning part you need for this is the EGR spacer though. The stocker won't seal properly against a GT40 upper. You may be able to use a Mustang part if you mod it to take the throttle cable bracket though.
          I got the intake&heads from a friend who had pretty much sold everything else off the engine and how hard is it to swap the levers. I havent seen or heard of anyone doing this but if anyone have one I will pay the asking price.
            very simple just grind off the little weld thingy on the bottom, wiggle the lever off, flip it over, and put a tack weld on it to hold it.
            '90 LX 5.0 mustang
            Big plans
              Here are a couple pics of the bracket I made using the stock marquis throttle bracket to use a mustang egr delete plate. Also kind of a pic of the bracket flipped for the throttle cable.
              bracket
              the flipped lever
              Hope this helps some.
              '90 LX 5.0 mustang
              Big plans
                What they said, swapping the lever is easy, I did it when I put an Explorer motor in my 91CV. And Explorer TB's can be had, saw one today at the boneyard. As far as the EGR spacer does, I had my original one bored out and used the Explorer gasket, it looked like a match, at least good enough of a match, and so far so good!!
                  oh okay i wasnt really going through the process of thinking at the time, i thought a ford lightning throttle body from bbk would fit, but really it was just a mustang. I suck at welding but it seems simple and how much did you bore the spacer.
                  ~also thanks from the pics&help
                    stock lopo bored to 63 mm
                      Lopo spacer won't seal against a gt40 upper. Need the Lightning part, or modified Mustang parts. Lopo spacer will seal against an HO upper, but thats about it's limits.
