One last question. With my GT40 manifold my oil cap wont fit because it will hit the upper intake when you turn it. I cant switch the valve covers so the fill is on the driver side cuz then it hits the cowl. Any suggestions for my Town Car? I'm trying to make everything look as stock as possible.
Oil cap wont fit with HO valve covers and GT40 intake
Cut the "wings" off the cap, or bent the actual fill tube slightly forward. Your using the stock stamped steel ones right? Or aluminum HO ones? Either way simple fix.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
knock the wings off of the oil fill cap......i used mk7 vavle covers on my 92 grand marquis and had to do this
doubt you can bend it that much, will probably crack the valve cover or break the filler neck
Those covers will crack if you wrench on them. If you're gonna try it, be sure you support the steel pipe and bend against your support, not the valve cover itself.86 Lincoln Town Car (Galactica).
You don't need to cut the wings off. The oil caps are 2 pieces. A top and a bottom. They snap together. Pop them apart, screw the bottom into the vc, then snap the top on. Reverse steps when removing. Remind me guys and I will make a video of how mine works next week and we can sticky it.
'90 LX 5.0 mustang
Big plans
I bent the tube on my car and it cracked when I romped on it. I was able to jb weld it in place though to have tons of clearance.
heck... I barely have 3 hairs clearance with my stock valve covers and stock intake in my 88 MGM. Well... it seems that way since my fingers always bang the intake when I take the filler cap off.
I just got a set of aluminum covers that had the neck cut off and professionally welded. Looks VERY professional. I got them from a seller on the NLOC. Thread linky for pics of the covers
If you know someone that can work with it the result is a modified filler without the buckling/kinks of being bent.sigpic
https://www.facebook.com/jason.baker.1614
1985 P43 Crown Vic, "Lightning Interceptor". Project is back on!
1987 P72 Crown Vic, EFI 351W (not my conversion), rusty and crusty parts car.
2006 Ford Fusion, 30MPG, premium sound, daily driver, 200K miles and still going.
2011 Ford Fucus, 36MPG, Sync, wifey / baby mobile.
Has anyone ever had success with heating and bending the tube, while supporting the tube at the base?Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
I had success in cracking the tube off the valve cover.
I then jb welded it in crooked. Took FOREVER to fill up oil. Should have nipped away at the excess before it was jb welded in place.
Its cast aluminum. I dont see it bending at all.~David~
Is the tube aluminum? I was always under the impression it was steel. That might bend if you heat it, aluminum will do nothing but break. I half suspect you'd have to use something that will fit snug into the bottom of the fill tube for support and dimple the steel where you heat it to give it someplace to bend.
Another option if its steel, cut a pie slice out of it, bend the tube forward, then weld the cut up.86 Lincoln Town Car (Galactica).
