hey guys i have a 89 vic with a t-5 swaped into it. i didnt do the swap and trying to fix what was done half way. my first issue is the car bucks and shakes at low rpm in a higher gear 3-5th. if the car is below 2000rpm it will start to shake. if you downshift it comes out of it.
the second issue i have is the clutch pedal assem engages on the floor and is a add a pedal instead of the full mustang pedal swap. i ended up puting a steeda adjustable cable in it and it work for awhile but im starting to lose adjustment again. so my main question is how hard is it to put a mustang pedal assem in the car.
my third issue is the transmission has started to make a gear noise louder than the normal growl that increases speed with the car. its mainly 1st and 2nd gear. still shifts fine just noisy.
the car also has the stock 2.73 open which i want to change out soon. any help would be great thanx ryan
