stock stainless shorty headers
    stang stainless headers with the inner gobs of weld ground out at the ports to pick up the flow some. Its 409 stainless i believe so the surface had a rust colour but no actual rust.
    $50 plus shipping
    Stock ones are not stainless, just coated in a rust inhibitor. GLWS.
